Hyperblink fix for 92-94 SC w/ 97 Taillights
Old 03-19-08, 05:31 PM
  #31
sc250tt
sc250tt's Avatar
Originally Posted by Ac93sc
Do you still get the dash light on when you hit the break??
That light was removed a long time ago .
Old 03-19-08, 06:54 PM
  #32
JesLet
JesLet's Avatar
Originally Posted by sc250tt
I just got back from radio shack and they did not have the 6.8uF cap . where did you get the one your using jeslet?
I got mine at Fry's Electronics.
Radio Shack has limited supplies.
Old 08-15-08, 06:42 AM
  #33
mr2tosc4
mr2tosc4's Avatar
there are two clips on that brown cover, i think to be able to use two thumbs to unclip the cover you'll need to remove the lower trim where the green light sits to clear your other shoulder. it's a tight squeeze in there. i thought it only had one so I'll try again tom when i have more time.
Old 01-06-09, 07:32 PM
  #34
sam430
sam430's Avatar
I guess this can be done to the brake light too. Anyone tried it?
sorry I didn't search... been doing search all day long looking for info on how to replace the front signal light with led.
Old 01-06-09, 07:55 PM
  #35
TheMole
TheMole's Avatar
You mean the brake light failure indicator? Not sure if theres a fix out there for that yet, but you can just pull the bulb if it bothers you that much.
So you want to replace your signal bulb with an led bulb?
Old 01-06-09, 08:07 PM
  #36
sam430
sam430's Avatar
I already replaced almost all my bulbs with LED. They have relays for 16 bux I don't know if it's a better solution or different solution to adding capacitors.
If it's the same solution, then I'd rather solder it myself than pay 16 bux.
http://www.v-leds.com/Shop/Control/P...9026/SFV/32481
although I'd prefer the variable blinking rate.
As for the brake light warning...maybe something can be done on the relay itself rather than increasing the resitance on the line. Correct me on anything, except for grammar I'll be reviewing it soon.
Old 02-08-09, 06:07 PM
  #37
Amini9
Amini9's Avatar
Bringing from the dead...
Anyone found out a way to fix the brake light failure indicator yet?
Old 03-30-09, 02:51 PM
  #38
Ratatat
Ratatat's Avatar
put in all LED's. Added cap to flasher. flashes just fine for he emergency's. No flash what so ever when trying to turn. Any one else have this problem.
Old 03-30-09, 03:17 PM
  #39
TheMole
TheMole's Avatar
You may have the problem that OLT explained on post #2 of this thread.
Old 03-30-09, 07:16 PM
  #40
Ratatat
Ratatat's Avatar
will try adding resistors tomorrow to see if that helps
Old 03-30-09, 07:38 PM
  #41
Enigma8246
Enigma8246's Avatar
has no one heard of these?
http://www.eautoworks.com/product-Led-33226.htm
They're made for when you upgrade to LED's. They make the car think there is a 1156 or 1157 bulb. I have them on my tails and no hyper blink. best part is if you wire them in with the harness for the tail and you switch your tails again, you don't have to modify your flasher depending on which tails you put in.
do a little searching. i've seen them as cheap as $5.
Old 03-30-09, 07:41 PM
  #42
Ratatat
Ratatat's Avatar
Thats what I have, got 4 of them.
Old 03-30-09, 09:44 PM
  #43
DONT SLEEP
DONT SLEEP's Avatar
Does anyone know how to access the kick panel? Do you have to remove the whole carpet at the bottom? This seems like a lot of work to get to a fuse box.
Old 03-30-09, 11:45 PM
  #44
TheMole
TheMole's Avatar
To access the flasher unit, you do not need to remove any carpeting. Just stick your head under there and you should see the beige/tan colored box.
Old 03-30-09, 11:51 PM
  #45
Ryeno
Banned
Ryeno's Avatar
The easiest way to fix all the problems is to take 3 bulbs from the original tail lights. Then just splice them into the new wiring harness. Then make a Plexiglas case so the bulbs float in air. Then just put the box into the spare tire well and cover it up with the lexus floor mat. Use removable spade adapters so that you can disconnect the bulbs incase you need to remove the tail lights and your done.
Quick Reply: Hyperblink fix for 92-94 SC w/ 97 Taillights
