One bad strut (front), replace both?
Old Dec 12, 2007 | 07:16 PM
V300Altus's Avatar
V300Altus
Default One bad strut (front), replace both?
I have a knock over bumps when driving coming from front left suspension. Front left fender well has 1 finger fender gap. Front right has 2 fingers. Same size tires. Is my shock/spring bad? Should I replace both front shocks at the same time or just the one? Thank you for your advice.
Old Dec 12, 2007 | 07:58 PM
574-SC300's Avatar
574-SC300
If you have one going bad, most likely they are all in poor shape.
Old Dec 12, 2007 | 08:01 PM
Lexus082's Avatar
Lexus082
Yes, always replace them in pairs. Either both fronts or both rears depending on what you need to replace. This way they approx. equal amount of wear. How many miles do you have on them. Also check the spring insulators which is the rubber covers that protect the shock/strut rod from dirt and water,etc. They will eventually rip and fall apart. Also check bump stops and upper mounts.
Old Dec 12, 2007 | 08:30 PM
Spitfire86's Avatar
Spitfire86
If you're driving stock I have an extra front pair of struts with about 30k miles on them if you want. Just pay for shipping from CA. Another CL member gave them to me but then I switched to TT suspension all around so no longer need it.
Old Dec 16, 2007 | 07:52 AM
vinh's Avatar
vinh
these are one of those things where you are highly reccomended to replace both, but if you're mad broke replacing one wont kill you.
Old Dec 16, 2007 | 10:08 PM
5sp_jzz30's Avatar
5sp_jzz30
just get coilovers
Old Dec 17, 2007 | 08:42 AM
GSPfan's Avatar
GSPfan
I would agree, might want to change both
Old Dec 18, 2007 | 01:36 AM
fwynn's Avatar
fwynn
id say change ALL 4...
Ruppy
GX - 1st Gen (2003-2009)
Oct 25, 2019 08:42 AM
Iknowspurg
Suspension
Jan 11, 2014 08:10 PM
father
May 24, 2010 08:07 PM
JAB
RX - 1st Gen (1999-2003)
Sep 29, 2008 01:53 AM
thang tran
Sep 20, 2008 01:38 AM
