found these headers
Ok, here is the video. Sorry about the wind it was really blowing. I guess this is a good time to ask... you can't tell in the video but when I launch both my tires spin together, they always leave matching skid marks. I think that the rearend is stock. On my sc400 if I break launch it will churp both tires but then only one spins and I don't see why it would be any different unless my rearend was an LSD (wishfull thinking) and if it is not a LSD then would I need to upgrade if I already put power to both wheel.
http://www.youtube.com/watch?v=eRL1l8zyQvQ
so are you still on stock exhaust? you just have the headers with the additional mid pipe right? hows the cabin noise for highway driving.. I do alot of long distance driving cause i go to school in another city.
xspsi6 did you do anything to your fuel system to run the 150 shot and did you check your plugs to see how it was doing. I would think that a stock 2jz-ge could take a wet 150 shot based on the fact that you can boost for alot more than that.
I tried out the 100 shot and WOW It feels like I doubled the shot. I'll bet that it added about 50 pounds of torque but like I thought any gear other than first gear the clutch just does not stand a chance. I think I will go a head and change the clutch. I'm thinking about the centerforce clutch II so any feedback on this clutch or recommendation is welcome.
Let me know how it turns out.
Thanks guys.
If you adjust the timing a few deg does it keep it retarded after you disconnect the jump wire?
Thanks
Thanks
Are you able to keep your cats or install a high flow cat with these?
Because I really dont like stinky cars...
Its a lexus not a ford or chevy.
hey guys i have a question about the O2 sensor on the OBX exhaust, i know there are two O2 sensors on the header and one on the mid pipe correct me if im wrong, but anyway on my stock exhaust on the second cat which is where the OBX mid pipe would go i dont have an O2 sensor, is this going to create a problem or could i just plug the whole where the O2 sensor would go?
GrantReid
Oct 11, 2017 11:44 AM
