SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 08-23-17, 12:29 PM
  #5926
Boostluv86
Boostluv86's Avatar
Originally Posted by Blkexcoupe
Everyone has different definitions of extensive. Those will poke in the front and rear. 235/40 on a 9.5 should be a good enough stretch to clear a roll and pull with some minor camber (-2).
How about if i went with Enkei Raijins, i was thinking 18x8.5 +35 front and 18x9.5+ 15 rear. Would that fit? What size tires would i need?
Old 08-23-17, 11:12 PM
  #5927
Blkexcoupe
Blkexcoupe's Avatar
Fronts will fit with a roll and will leave you with room to get a spacer if you need it for LS brake upgrades. The rear will fit very similar to the other wheels you asked except they'll be sunken in by 5mm. You'll still need a roll and some minor camber (-1.2 to -1.5)
Boostluv86 (08-24-17)
Old 08-24-17, 08:13 AM
  #5928
Boostluv86
Boostluv86's Avatar
Ok cool. Will 245 (front) and 255's (rear) fit with a roll and that slight camber? The car will be on Tien Flex-Z coilovers. Would i be better off running a +35 in the rear?
Old 08-24-17, 10:10 AM
  #5929
Blkexcoupe
Blkexcoupe's Avatar
It really depends on what your using your car for, how low your car is going to be, and what brand of tire your going to use. It'll fit if your car isn't slammed and the roll is done perfectly flat.
Old 08-24-17, 10:28 AM
  #5930
Boostluv86
Boostluv86's Avatar
It'll be a drivers car, not planning on slamming it too far, just going with the preset height from Tein, believe it's around 1.75-2" drop or so. I'd like the top of the tire flush with the fender
Old 09-14-17, 09:54 PM
  #5931
kostas86
kostas86's Avatar
I am looking to swap over some wheels from my 300zx to my stock '99 sc300. Volk GTM 18x9 w/38 offset in the front on 245/40 and 18x10 w/42 offset in the rear on 285/35. From reading through this thread, appears that they should fit well.
Old 09-24-17, 07:27 AM
  #5932
SQ400
SQ400's Avatar
Ok just picked up another SC400 a 95 with 131000 on the dail. My 93 400 has about 270000 on her now and time do do timing on her.
Got the 95 for great deal she runs great but has the biggest rims on a SC i seen and hate it, 22's.
I looking to run some 19" and found the style i want. So what would be best. Here what available. I would like to have it as close to even with the finder as possible with having to roll and/or shave if possible. I plan to do very moderate drop with a set of stock Supra spring for now.
If guys recommend which of the following would be best and tire size.
19x8.5 Front
19x9.5 Rear
+32 offset
Or
Same size with a +40 offset
Thanks for all the help in advance.
Old 09-27-17, 04:47 PM
  #5933
maynanator
maynanator's Avatar
Work Schwert sc1 19x8.5 +35 19x9.5 +35
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-img_9953.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-img_9956.jpg
Old 10-05-17, 12:14 PM
  #5934
SactoSC3
SactoSC3's Avatar
Default would these fit?
My SC300 has the factory 15" and I found a set of replica LFA wheels in 19x8.5, 38mm offset, 19x9.5, 45mm offset. 235/35-19 FR and 265/35-17 RR
Car is bone stock and probably needs new shocks all around. Just wasn't sure if the tire/wheel combo would fit with minimal/no mods.
Other option is to go with a set of 2013 GS350, 18x8, 45mm offset, so I can rotate. This is my daily driver, keeping it stock and simple/close to OE.
Thanks for the advise.
Old 10-05-17, 12:23 PM
  #5935
Duck05
Duck05's Avatar
They will fit with those specs. Might look weird at stock height though..... "Replicas" implies a lower cost so just make sure the alloy and build of the wheels is safe..... Pictures before and after will help too.....
SactoSC3 (10-05-17)
Old 10-05-17, 12:45 PM
  #5936
SactoSC3
SactoSC3's Avatar
one of the wheels has a repaired crack. seller says it holds air, but that's making me a bit gunshy. otherwise, they look decent and they're a solid improvement over the factory 15"s.
Old 11-04-17, 02:36 PM
  #5937
JDM Master
JDM Master's Avatar
hey guys need sum advice. I purchased sum wheels for my sc the spec is 18x9.5+4 front and was planning on running 235 40 on them. Do you guys think i'll be alright with this tire size as far as clearance or should i go with with 225 40? Thanks in advance for any help/info.
Old 11-06-17, 08:25 AM
  #5938
Blkexcoupe
Blkexcoupe's Avatar
9.5 +4 is aggressive. People usually run 235 for a 9.5 +12, so I'd recommend running the 225 to be safe.
JDM Master (11-07-17)
Old 11-06-17, 10:08 PM
  #5939
zenkiderek
zenkiderek's Avatar
****Official Wheel & Tire Fitment Guide for SC300/SC400****-ykpldto.jpg
18x9.5 +12
215/35
225/40
Old 11-07-17, 03:46 AM
  #5940
JDM Master
JDM Master's Avatar
Originally Posted by zenkiderek
18x9.5 +12
215/35
225/40
how much camber are you running in the front?
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
