SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 05-17-17, 08:32 AM
  #5896
Returd
Returd's Avatar
I haven't seen anything on hub diameter posted. What is the minimum hub diameter required. I assume larger hub diameters aren't a problem
Old 05-17-17, 09:11 AM
  #5897
Blkexcoupe
Blkexcoupe's Avatar
Originally Posted by Returd
I currently have BBS rims 17x8 with an ET of 42. Running 245 45 17's (just bought new rubber)
2 rims need replacing. I found a reasonably priced set of rims 17x8 with a ET35.
I'm lowered a bit from stock but not much.
Will I rub with the ET35"s?
I'm going to guess it won't be an issue, but the easiest way to know is to measure your car. Since both wheels are 8", 42 - 35 = 7mm, so measure your car and see how much space there is between your wheel and fender. If the gap is larger than 7mm, then you're good.
Originally Posted by MrBigNasty
So kind of new here. First post.
looking to get new set of wheels so I can run a 315/30r18 drag radial. I have looked at over 30 pages and hardly any one runs this big of a tire. I am wondering what offset I should get? I plan on getting 10" wide wheels so the tire will poke out more then the rim. Also open to going wider if I find the right rim. This is only for rear tire.
purpose -I will only be drag racing this car
Ride hight- have Megan coilovers so can adjust
rear fenders- are pulled (whoever did it should be taken out back and Beaten with whatever he did it with.)
tire size- 315/30r18 drag radials
Rim-
18x10 offset???
18x10.5 offset???
18x11 offset???
I hope I have thought of everything. Thanks in advance!! This is the first thing I have not found easily on the site!!
Check out page 386. I was discussing this exact same question with someone else.
60.1 is the center bore diameter for lexus. You'll want it the same size or larger. Toyota/Lexus is the smallest hub diameter I've encountered, so most wheels will be larger. You can order hub rings to fill in the gap if it bothers you.
Old 05-20-17, 04:09 AM
  #5898
718murdoc
718murdoc's Avatar
Will 19X9.5 19X10.5 +22-F+R VARRSTOEN ES1 fit a stock body sc?
Old 05-20-17, 04:46 PM
  #5899
Blkexcoupe
Blkexcoupe's Avatar
It'll require fender mods. Roll in the front and roll or shave in the rear. Fronts you'll be ok with a 245 or 255. You'll need 265 in the rear if you're really low or a 275 if you have some wheel gap.
Old 05-20-17, 08:49 PM
  #5900
718murdoc
718murdoc's Avatar
So if i use the tire sizes you suggested i wont need to roll the fenders or will i have to roll them regardless?
Old 05-20-17, 08:55 PM
  #5901
Blkexcoupe
Blkexcoupe's Avatar
You're going to have to roll them regardless if you want those sizes. Those tire sizes are to clear the fender after modification.
If you want no mods at all, then you're looking at something like a 9 +35 or higher in the rear. The fronts I'm not too sure what size fits without any mods.
Old 05-22-17, 09:51 PM
  #5902
JoeBlob
JoeBlob's Avatar
From what info I can find these are American Racing "Rebel" wheels 17x9 +24mm. And 245/45r17 on all 4 corners. Bought it like this so I need to dig a little deeper.
Pretty flippin flush. Glad to have the side skirt and rear aprons. Lines out jist right in my opinion
also last pic is from the CL ad, unlike the seller i know how to park between the white lines....
Old 05-23-17, 07:41 PM
  #5903
3stars1sun
3stars1sun's Avatar
Guys I need your help. Just got my 98 SC300 last week. I now have a chance to purchase the wheels I've been wanting for the longest. Racinghart Type C . Spec are 18x8.5 with 28 offset and 18x9.5 with 40 offset. I'm still on stock suspension but will lower the car an inch or 2 soon. Will these wheels work without any fender mods? Much appreciated
Old 05-24-17, 01:21 PM
  #5904
Blkexcoupe
Blkexcoupe's Avatar
At stock height you'll have no issues.
Once lowered, The rears will be fine. I'm not really sure about the fronts since I don't remember the clearance of oem fenders. I think you'll be fine or very close to them. Worse case scenario you'll have to shave some of the fender lip off. You won't need a complete roll.
Old 06-10-17, 09:57 PM
  #5905
MDNT_DRV
MDNT_DRV's Avatar
Thoughts?
Old 06-18-17, 05:54 AM
  #5906
MDNT_DRV
MDNT_DRV's Avatar
Hey guys I really need to decide on these:
i was hoping for a wider rear. The price is $1850 shipped. I need to decide today but I don't know how they would look at this size and offset
Thoughts??
Old 06-19-17, 08:29 PM
  #5907
Blkexcoupe
Blkexcoupe's Avatar
Thoughts??
They'll be sunken in, but its right on that gray area between needing and not needing fender work. I'd recommend running them with a spacer to be flush (at least a 15mm). If you do decide to buy them, then you could always move the 9.5 to the front and rebarrel the 8.5's. Relipping isn't an option since OZ futuras are 2 piece welded, so you'd have to replace the inner and outer lip.
MDNT_DRV (06-19-17)
Old 06-19-17, 09:06 PM
  #5908
MDNT_DRV
MDNT_DRV's Avatar
thank you for the info! how badly sunken in do you think they'll be? i'm not a huge stance/flush person and i was going to do a slight drop but not that much. don't have a problem getting my fenders rolled so i'll probably do that. and i was thinking about using a 5mm spacer to avoid any safety issues... seems like some ppl say 15mm is dangerous, so idk. i'll read up more on it. if i can do that with only extended studs, maybe i'll do that. thinking about 265/35/18 in the rear, 245/40/18 in the front.
ETA: are you sure they're welded? the guy said they've been relipped and are on stock barrels...!
Old 06-19-17, 10:53 PM
  #5909
Blkexcoupe
Blkexcoupe's Avatar
It won't be that bad, but it would look better with spacers.
The wheels I was thinking about in my head during my initial reply was Koenig Monsters (they look the same), and the ones I've dealt with were welded. After you asked, I realized I've never seen a set of OZ futuras in person (only koenigs), so I'm not 100% sure if they are.
MDNT_DRV (06-19-17)
Old 06-21-17, 01:03 PM
  #5910
paulwall4
paulwall4's Avatar
Default Merged with ****Official Wheel & Tire Fitment Guide for SC300/SC400****
will these fit a 92 sc400?
20x9 +32 offset
20x11 +35 offset
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
