SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 03-27-16, 06:05 AM
  #5686
SQ400
SQ400's Avatar
Guys will a 19x8.5 with +32 offset front and 19x9.5 with +38 offset rear work.
Thanks for all your help in advance.
Old 03-27-16, 01:04 PM
  #5687
Sc400NL
Sc400NL's Avatar
i run 8.5 J x19 ET 37 front
9.5 J x19 ET 33 back
with the rear quarters rolled , front will rub on hard turns lowerd with BC coilovers
245/35/19 front and 275/30/19 in the back Bridgestone potenza
it will give a flush look
Old 03-28-16, 04:18 AM
  #5688
Stavros
Stavros's Avatar
If the front wheels are 18x9.5 ET38 with 245 tyres, would they rub? Would a simple roll fix it or do I need to shave them? Lowered on coilovers.
Old 03-28-16, 07:15 AM
  #5689
Deegee
Deegee's Avatar
They'd rub for sure. Roll your fenders flat, i don't think a pull is necessary.
Old 03-28-16, 09:51 AM
  #5690
jwynn
jwynn's Avatar
Default Did u run the 275s up front
Originally Posted by ross3857
Jadu: ya thats what I was thinking too, wanted to make sure before i pull the trigger, the rims im getting are wrapped with 275 in front and 315 in the back. lol, need to calculate tire cost.
LatitudeNZ, yr front looks great, thanks for the pics, gave me some ideas in the back.
Hey did you ever get to run the 275s up front? Im about to buy a similar set up of 19x9.5 +40 275/40 in the front i just wanted to make sure they'd fit no problem.
Old 03-28-16, 04:32 PM
  #5691
jwynn
jwynn's Avatar
Originally Posted by Black_SC
got any pictures?
i have 8.5 in front with +24 and it sits really flush...but yea pics would help
Do you have any idea if 19x9.5 will fit up front with 275s and +40 offset ?
Old 03-28-16, 04:33 PM
  #5692
jwynn
jwynn's Avatar
any idea if 19x9.5 will fit up front with 275s and +40 offset ? Anyone???
Old 03-30-16, 06:53 AM
  #5693
grumpi300
grumpi300's Avatar
looking for 19 inch rims with a 225/35r19 fit tire. what offset should i get, i want to be the same all around so i can rotate my tires still. i dont mind pulling the fenders a little bit. i really dont feel like reading 381 pages just to find my answer. please halp.
Old 04-13-16, 11:36 AM
  #5694
MrSparxxx
MrSparxxx's Avatar
Default 19x10.5 frt 19x11.5r
Hey I'm new to the Forum. Have a 99 SC 300. Looking at getting wheels built. Want to go 19x10.5 frt 19x11.5 rear. Gonna do LS400 BBK. Want to have a deep lip. Maybe run 235 frt 265r. Not gonna slam the car. What would be an et that will work? Don't mind small pull and roll. Thank you in advance I've looked for two months
Old 04-13-16, 01:14 PM
  #5695
Tabaka
Tabaka's Avatar
I have 18x9.5"+12 - 235/40 up front and would like to install the 25mm Vertex Aero Front Fenders. Are my wheels going to be sunken by a lot? I'm currently pretty flush with a roll and rubber mallet pull.
Old 04-14-16, 10:09 AM
  #5696
Blkexcoupe
Blkexcoupe's Avatar
If you want deep lips all around, then I wouldn't recommend the LS400 brakes. You'll lose at least 1/2" of lip by running the LS400 brakes. Run some aggressive brake pads in the stock SC calipers if you want more performance.
I'm guessing it'll be sunken in by about 20mm or 25/32" with your current setup. You could compensate for this by running a larger tire in the front or a spacer.
Old 04-15-16, 12:39 PM
  #5697
Tabaka
Tabaka's Avatar
I hate spacers, it's the reason why I got low offset wheels in the first place. What if I ran a 18x10.5" +22? My fronts have some curb'age and clearcoat issues anyways, so I wouldn't mind ditching them. I guess I'd need to think about what tire size would work best though. I have 18"x10.5" +15 in the rear right now with a 265/35.
Old 04-15-16, 02:52 PM
  #5698
Blkexcoupe
Blkexcoupe's Avatar
A 18x10.5 +22 would only stick out 3 mm more than your current wheels, so still sunken. It looks like you have varrstoen ES1 wheels, so if I were you I would test fit the rear wheels in the front with vertex fenders. If it looks good, then I would get 18x10.5 +15 with 265/35/18 tires all around, so I could rotate. The wheels will still be a little sunken in, but it should still look good as long as your car isn't completely slammed.
Old 04-18-16, 02:51 PM
  #5699
MrSparxxx
MrSparxxx's Avatar
Default 19x10 frt. 19x11.5 rear.
OK guys and gals. I'm new to the Lexus community. And thank you all for all the help. I'm gonna have a set of wheels made. Been trying to get the specs down for months. I want deep step lips. Gonna do LS 4 BBK. Front 19x10 hi disk. Rear 11.5. Not gonna slam the car. Wanted to know good et . Gonna stretch tires. Please please can some wheel fitment experts help me out
And can someone post some pics
Old 04-19-16, 08:44 AM
  #5700
Tabaka
Tabaka's Avatar
I'm pretty much done with these wheels. I'd like to get a custom set of 3-piece wheels next year, and would like my measurements to be as accurate as possible. Why can't they make aftermarket fenders with the cool air slot at a reasonable measurement, blah /rant
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
