SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 06-01-14, 08:28 AM
  #5296
OG Dada
OG Dada's Avatar
ninjaCEO, you can make it fit.
My wheel specs;
19x10 +15 235/25/19
19x11.5 +10 275/30/19
Old 06-01-14, 12:59 PM
  #5297
Sc400NL
Sc400NL's Avatar
Originally Posted by SOARER525
Thanks! I'm on normal camber just the way I wanted, I love it! Depends if your dropped or not. I'm on Megan coils and I had to bring it up 3/4 of an inch to be safe n I'm more than pleased except for the fact that I had to remove my front splash guards completely bc it was rubbing still so they aren't on anymore. It left my fog lights bare naked with no protection for moisture to get in and burn my HID bulbs and GUESS what happened...not even one day n they were out. CANT WIN! That's what u get when u mess with the splash guards. I have to figure it out otherwise it's gonna be a chronic issue.
ah yes those splash guards have a purpose lol , but what do you think would solve the problem of rubbing your splash guards ? smaller wheel or another tire setup ?
and what about the back ?
i have ordered BC Racing coils and i want to go low ...not slammed but low without negative camber
Old 06-02-14, 12:15 PM
  #5298
deputy865
deputy865's Avatar
What would I have to do to my fenders with this wheel/tire set up?
Front: 19x9.5 +22
Rear: 19x11 +25
Front: 235/35/19
Rear: 265/30/19
Really want a flush look and to fill my fenders proportionately with a good wheel/tire combo.
My other wheel options would be
18x9.5 +22
18x10.5 +22
No idea on tire size...?
As long as I can reach my goal above and not have to do some major fender modifications, I'm happy. A roll is ok.. Prefer not to pull. I also have reason to believe either wheel size will clear LS400 brakes.
I still have yet to lower my car, but the look I'll want will be to have no fender gap. I like when the tire follows the contour of the wheel well perfectly.... and with a flush look.
Thanks guys, I'm completely new to purchasing wheels as I've never done it for one of my cars.
Shane
Old 06-02-14, 02:05 PM
  #5299
ninjaCEO
ninjaCEO's Avatar
My wheel specs;
19x10 +15 235/25/19
Alright cool that's super aggressive too!
Once I get the everything done I will post it up!
Old 06-03-14, 08:24 AM
  #5300
jadu
live.love.laugh.lexus
jadu's Avatar
Front: 19x9.5 +22
Rear: 19x11 +25
Front: 235/35/19
Rear: 265/30/19
18x9.5 +22
18x10.5 +22
Shane
No major fender mods to fit those 18s or 19s. For both sets of wheels, you will need to roll the rear fenders completely, and a slight roll in front depending on how low you are. 235/40/R18 and 255/35/R18 would suffice for the 18s. As for brake clearance, you will need to research the wheel manufacturers' face of the disk (i.e. low, med, high)
Old 06-03-14, 08:27 AM
  #5301
jadu
jadu's Avatar
Originally Posted by Supremeg56
Before I look into buying these wheels a friend of mine is selling for dirt cheap the specs are rears are 19 x9.5 tires are 275/30/19 offset 32 front are 19x8.5 tires 235/35/19 offset 36. Does anyone know if this will involve rolling the fenders. or if the wheels will have that sunken look to them To be honest right now I have stock suspension but plan on buying coil overs soon.
Any help would be greatly appreciated
these would fill the wells with stock suspension just fine. Given those offsets, I do not think you will need to roll the fenders
Old 06-03-14, 06:06 PM
  #5302
fmayi1101
fmayi1101's Avatar
Originally Posted by ninjaCEO
I have some extremely aggressive wheels 18x10 -0 front and 18x11 -0 rear.
I'm running 255/35 in rear, and a 225/35 in the front
here are the pics, I have ARP extended studs for an IS300 and I plan to run a 3mm spacer to clear LS460 calipers.
here's the pics of the fitment (rx8 trolling in the back.)
Will this work?
more pics man.
Old 06-10-14, 08:07 PM
  #5303
SOARER525
SOARER525's Avatar
245/40/18x9 +25 offset rolled and shaved
275/35/18x10 +25 offset rolled & shaved
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-image.jpg
Old 06-11-14, 08:24 PM
  #5304
Need4Speed
Former Sponsor
Need4Speed's Avatar
Awesome so many SC builds
Maybe I should post up our SC shop car we have.
Actually I will pics this week.
Old 06-16-14, 05:54 PM
  #5305
Bdub215
Bdub215's Avatar
My setup is probably more tame then most since these wheels werent bought for my SC in the first place:
XXR 522 17X8 F+R +35 offset
(225/45) small stretch
On TT Teins/Adjustable KYB
2 Finger front and 1.5 rear.
Old 06-16-14, 09:59 PM
  #5306
SOARER525
SOARER525's Avatar
Readjusting rear Megan coils
Old 06-18-14, 12:34 AM
  #5307
RidinLow
RidinLow's Avatar
Default ..
Slammed on 20X10+19 and 10.5 +12 tucking all four corners
Old 06-20-14, 05:08 PM
  #5308
Durrby
Durrby's Avatar
What sizes for 20x10+25 and 20x11+28 slightly tucking tires now.
Currently 20x8.5+38 235/30 and 20x10+40 275/30 rolled flat all around. Wanna stay around the same sidewall heights that way I don't have to readjust the car height to compensate. Will do so if need be.
Currently sits like this
Old 06-20-14, 05:23 PM
  #5309
jadu
jadu's Avatar
The 20x11s +28 would poke 24mm more than your setup now and it would sit near flush with the rear fenders if not poke a few mm past it. You could probably go 255s front and 275s rear, 30 series profile all around. This is a safe size as tire manufacturers run wider than others, and reduce chances of rubbing.
Old 06-20-14, 05:32 PM
  #5310
Durrby
Durrby's Avatar
Ok thanks! How about the front fitment. It was suggested I run 235/30 up front and 255/30 for the rear. Just trying to gauge what I would need. I may buy the tires after mounting them to see where I'm at with my current height and camber.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
