Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#4441
been reading this thread for a few hours....need some help...
19x8.5+15 front
19x9.5+20 rear
how can i make these fit and what tire size should i run
btw right now running nf210 tanabe but will soon be on bc coilovers
THANX in advance for the advice
19x8.5+15 front
19x9.5+20 rear
#4446
I read at least 20 pages of this thread prior to buying my current wheels/tires setup. One might say, "good for you, you have plenty of time to waste". News flash bro, modding cars is a hobby, and hobbies are times you wanna waste instead of doing NOTHING, which really is wasting time. Am I making sense?
Big ups to my homie raine for taking time in making a chart and stuff to make it easy to understand.
#4447
darkling mentioned it in text that he was going to put on r35 gtr wheels in this thread but I found no pictures. Does anyone have a pic with them on a sc or a supra for that matter? Stats: 20x9.5 +45, 20x10.5 +25. SHould fit if lowered, rears will stick out if non-lowered
#4448
Hello all, I'm looking at some Work Rezax 18x10 & 18x11 +19 all around. What would I have to do to fit the fronts? I have LS brakes and all 4 corners are rolled. Thanks!
also checking out the rezax in our classifieds. 18x9.5 & 18x11 +13 all around
#4449
I recently put 18x9.5 rpf1s on my car, and my car has coilovers. Now I'm experiencing a humming noise, and a slight vibration threw the steering wheel above 35 mph. They are not rubbing, so my question is do you guys think its from the wheels not being properly balanced? Or could my car possibly need an alignment? I never noticed it with stock wheels and tires.. any help would be appreciated. Thanks.
#4450
Vibration after just changing wheels is usually wheel balance, get them checked out and make sure you hand torque the lug nuts (no air guns!!)
Also, you are using conical lugs right?
#4451
-are your lug nuts torqued down to spec? If not, grab a torque wrench and check every single one
-are you running the correct lug nut? Oem mag type lugs won't play nice w/ your enkei's. Iirc those call for tuner lugs or was it accorn style lugs
-are you running hub centric rings?
-is tire pressure even?
-after your coilovers ... did you get an alignment?
-are you running mismatching tires that could possibly create said noise/hum?
-have you tried goin back to oem wheels to see if the car still has the same issues/problems?
I recently put 18x9.5 rpf1s on my car, and my car has coilovers. Now I'm experiencing a humming noise, and a slight vibration through the steering wheel above 35 mph. They are not rubbing, so my question is do you guys think its from the wheels not being properly balanced? Or could my car possibly need an alignment? I never noticed it with stock wheels and tires.. any help would be appreciated. Thanks.
#4452
Yes, I'm using acorn lug nuts so they seat properly. And another thing i forgot to mention is that I'm not using hub centric rings at the moment. So I suppose that could be the problem right there. I'm going to order some asap and see if that solves my problem. If not I will have the wheels rebalanced.
#4453
