SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 06-27-12, 02:03 PM
  #4306
silverAg
silverAg's Avatar
Just wanted to get some advice on tire sizing for my CE28N mag blue wheels their specs are
18x9.5 +15
18x10.5 +18
I'm thinking 235/40 front and 255/35 rear overall diameter difference would be .4 of an inch .2 radius front to rear difference as well. I want to get a little bit more meat on the rear since I want more traction for my 2JZ but didn't want to change my wheels. Oh and how much modification on the rear fender? I have rolled fenders as well but wanting know if there's pulling involved
thanks
-C
Old 06-27-12, 06:33 PM
  #4307
CalitriSC
CalitriSC's Avatar
18x9.5 +15
18x10.5 +18
thanks
-C
You should be fine if they are rolled flat. You could also do a 235/35 in the front, thats what I have. Or 265/35 in the rear, it will just be a little taller than the 255/35.
Old 06-27-12, 07:40 PM
  #4308
silverAg
silverAg's Avatar
Appreciate the input. So 235/40 with 265/35 or 235/35 with 255/35 combo? And front fender no rolling involved?
Old 06-28-12, 12:53 AM
  #4309
CalitriSC
CalitriSC's Avatar
Fronts would need a roll, but nothing crazy.
Old 06-29-12, 11:04 AM
  #4310
jminor
jminor's Avatar
Just looking for some feedback here..
After searching alot of this thread I had decided that I wanted to go w 245/40/18x8 +40*offset. I do not want to lower the car or do any fender mods. Today now I have an opportunity to buy a beautiful set of enkei rims and they are sized Front: 18x7.5 +45mm offset. Rear: 18x8.5 +50mm offset
Thoughts on tire size and how it would look or should I pass and stick to my original plan?? Thanks!
Old 06-29-12, 01:51 PM
  #4311
raine
raine's Avatar
The first size (245/40-18, 18x8 +40) will fit. But it will look like an SUV at stock ride height.
The new numbers (7.5+45 / 8.5+50) are practically exactly the same as OEM IS350 wheels, with the same offset but the one small exception that the front size you listed is 1/2" narrower than IS350 front. These would look good with IS350 OEM tire sizes (225/40 and 255/40)...
BUT
...again, at minimum you'll need lowering springs to make it look like a car, not an SUV. A set of Espilir ASD's don't cost much, and will enhance the look of your car with that wheel combo you listed. Look for my post in this thread that shows my car on OEM IS350's for a reference.
Old 06-30-12, 07:16 AM
  #4312
jminor
jminor's Avatar
Thanks, found the post but the pics were no longer posted, just red x
Old 06-30-12, 11:36 AM
  #4313
jminor
jminor's Avatar
does anyone have a pic of the 350 15 spoke wheels from an 06? I have an opportunity to grab either those or the infiniti wheels.. The lexus ones have rubber and the infinitis do not
Old 06-30-12, 08:59 PM
  #4314
jminor
jminor's Avatar
Well bought the wheels, buddy says they were an option for the 350, I bolted them on and they look great, does it sit higher yes, can I live w it, yes.. Do the bigger wheels throw the speedo out? Raine, thanks for your help appreciate it!
Old 07-04-12, 06:24 AM
  #4315
stvnmj
stvnmj's Avatar
I have a chance at getting some wheels with these specs f19x8.5 +39 r19x10 +43 with these tires
f245/40 and r275/35 are those tires a proper size and you guys think i would need to roll my fenders?
Old 07-04-12, 10:44 PM
  #4316
raine
raine's Avatar
No prob bud
I'd suggest 235/35 front; both wheels will be sunken in a little, unless your ride height is super low you shouldn't have to roll or pull.
Old 07-05-12, 02:29 PM
  #4317
cheddarSC4
cheddarSC4's Avatar
ok so i snagged another set of wheels basically paid nothing for them. only problem is they are bmw lug pattern so here is what i have:
19x8.5 et 20 19x9.5 et 30
ill have to run adapters and they are 19mm so ill have a +1 up front and +11 in back. does anyone see any major issues with this? fenders will be rolled and pulled and tires are 225 35 all around. appreciate any help!
Old 07-05-12, 03:37 PM
  #4318
CalitriSC
CalitriSC's Avatar
I don't see you having any issues with that set up.
Old 07-05-12, 08:11 PM
  #4319
cheddarSC4
cheddarSC4's Avatar
Perfect that's what I wanted to hear. Thanks man!
Old 07-08-12, 02:57 AM
  #4320
snakehead
snakehead's Avatar
1998 SC400 , Work rims Front:18x9.5 +15 Rear:18x10.5 +22 , Would this be a nice staggered set up or not? What would be a good tires size .
How much fender rolling/pull would i need front or back?
Thanks,
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
