SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 09-14-10, 08:45 PM
  #2851
SChema
SChema's Avatar
Originally Posted by magneti
overload of info for my brain.
I have a 98 sc300 and getting wheels 19 x 8.5 and 9.5. offset 23 and 24.
what tires can i get that wont require any modification to fenders to look closest to flush.
Depends on how low your stance is going to be and your suspension geometry.
Originally Posted by KC83
Hi everyone,
I am currently running some unknown offset 19in wheels(running 10mm spacer in front). What offset of wheels I should get? I am running LS front brake calipers.
1 finger wheel gap in the back, 2 in the front
Thanks everyone in advance.
That's going to depend on how wide of wheels you want to get and the size tire you want to run.
Old 09-16-10, 03:13 AM
  #2852
KC83
KC83's Avatar
I am running 215 35 19(?) front and 255 35 19 in the back. I plan on running 19x8.5 in the front and 19x10 in the back. Thank for the help.
Old 09-16-10, 09:28 AM
  #2853
magneti
magneti's Avatar
3rotor has been a great source of insight for me. good guy.
Old 09-16-10, 11:22 AM
  #2854
SChema
SChema's Avatar
Are you wanting the stretched look? I ran a 245 on a 8.5" on my old wheels to give you an idea. Personally I would run at least a 275 on 10" wheel. If you are going for the stretch you can run a bit more aggressive offset.
You will need a 10" wheel with a 23 offset to roughly match the fitment of how mine sits right now in the rear. With a 255, you could be a bit more aggressive of course, maybe high teens are possible. As for the fronts you could go with a 24 offset. Same as the rears, running a smaller tire will allow you to be a bit more aggressive, I would think high teens wouldn't be too much of problem.
Running the 215's will give you a slight raked look, since the overall front tire diameter will almost be an inch smaller. I don't have much experience with stretched fitment, hopefully someone else can chime in on this for you, good luck.
Old 09-16-10, 02:43 PM
  #2855
RaynArt
RaynArt's Avatar
Originally Posted by sckyle
18x9 +7 215/35
18x10 +11 225/35
love it
i need some spacers lol
Old 09-17-10, 12:11 AM
  #2856
LexmanBLY
LexmanBLY's Avatar
This thread is very informative.
Old 09-21-10, 06:15 AM
  #2857
turbodremz
turbodremz's Avatar
17x9 +35 F / 17x10 +25 R------sunken or semi flush? I know they are 17's, but I love 17's..anyone running something similar with a pic?
Old 09-21-10, 06:36 AM
  #2858
SChema
SChema's Avatar
These offsets and widths are similar to mine. My 18's are just a little bit more aggressive, these 17's should look pretty good. Depending on height and tire sizes you choose will determine if you need to roll or shave the rears. A 5mm spacer wouldn't hurt to use in fronts either.
Image on post #2836.
My fronts now have an 8mm spacer instead of the 5mm pictured.
Old 09-21-10, 07:15 AM
  #2859
CP_Ree
CP_Ree's Avatar
That front should need like a 10-12 mm spacer imo to be flusher. THe rear will need a 5mm spacer to be flush and still straight camber-wise imo.
Old 09-22-10, 02:28 AM
  #2860
MEQ
MEQ's Avatar
PLEASE HELP ME OUT!
Hey guys, I have a few questions that i hope you guys can help me answer. I'm kinda new to the scene so bare with me if these questions are stupid or if they've already been asked here (I've been looking through it for hours and haven't found an exact answer to my question.)
I recently bought a completely stock 2000 SC400. The first thing i want to do to it is put on some wheels and then lower the car just a little (about 1", maybe 1.5" at the very most). Considering that i may lower the car up to maybe 1.5", i wanted to see if some wheels would fit WITHOUT having to do any modifications to the fenders such as pull or roll them.
Would it be possible for 19X8.5 +35mm Front and 19X9.5 +45mm Rear wheels to fit my car (No modifications to fender). Would they fit on Stock suspension, 1" drop, and 1.5" drop?? If so, what wheels should i run on them. I want the regular tire fitment; i dont like it when the rim looks like its sticking out further than the tire.
Please help. THANKS YOU SOOO MUCH to whoever takes there time to read this and help me out.
Old 09-22-10, 06:04 AM
  #2861
SChema
SChema's Avatar
Yes, they will fit without any modifications. I would suggest running a 10mm spacer in the rear to push the rear out a bit more or you could get a 35 offset rear. Tires, I would recommend 245's in the front and 265 or 275 in the rear.
Old 09-22-10, 09:21 AM
  #2862
abounly
abounly's Avatar
how much of a spacer would i need for a 8.5 +30 for it to be flush? i was thinking of picking up either a 15mm or 20? i guess you can say that i am low
Old 09-22-10, 11:39 AM
  #2863
MEQ
MEQ's Avatar
What should my sidewall ratio be. 245/__/19 Front 265/__/19 Rear
And are you sure they'd fit even if i would potentially drop up to 1.5"??
Thanks alot for the help!!
Old 09-22-10, 01:37 PM
  #2864
SChema
SChema's Avatar
Running 35 series in the front and 30 in the rear will do it. I was lowered to near no finger gap on 18x8.5 and 18x9.5 with 35 offset all around with the listed tires plus one aspect ratio, making the overall diameter similar to the 19's. My rear fenders were mildly shaved at the time. Worst case you can have a mild shave just in case; if you are going to be running the 45 offset in the rear, I don't think you'll have any problems with the stock fender lip.
Old 09-22-10, 04:45 PM
  #2865
turbodremz
turbodremz's Avatar
Thanks guys. Just waiting for the new lug nuts to come in. BTW the wheels are FNOR1C's in bronze. I will have some test fitment pics up once the new lugs come in.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
