SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 09-16-08, 07:37 PM
  #1951
craaaazzy
craaaazzy's Avatar
please give me ur input on the following combo. my biggest issue would be the tire sizes.
19x8.5 in the Front Offset35
19x9.5 in the rear Offset 40
235 35 ZR19 Front
265 30 ZR19 Rear
Old 09-19-08, 07:45 PM
  #1952
mike36
mike36's Avatar
should fit fine
Old 09-19-08, 11:00 PM
  #1953
nysupraman
nysupraman's Avatar
Originally Posted by nysupraman
With a mild say one inch drop, what size tires would be able to clear the stock fenders without a roll or a cut? Would they be flush?
18 x 8 +26 fronts and 18 x 9 +20 rear
anyone...?
Old 09-20-08, 01:20 AM
  #1954
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
even with stretch i think you would need to roll the rears for a problem free driving...or you can always let it ride high and go slowly over bumps
Old 09-20-08, 12:26 PM
  #1955
Mattmannz
Mattmannz's Avatar
You can't have low, flush and stock fenders, it just isn't possible.
Those wheel specs will be close to flush which will cause you problems even with stretched tires.
Just get the fenders done as you will end up wanting to go lower and wider soon.
Matt.
Old 09-22-08, 06:01 PM
  #1956
matrixgts
matrixgts's Avatar
their is no way i can check all of these to see if someone have this set up if you do guide me to the pic.but here goes rim size 20x8.5 all around offset 38 tires 255/35/20 how will this look and i allready have the rims but not the tires.thanks for your help fellas
Old 09-22-08, 10:54 PM
  #1957
Kaydee
Kaydee's Avatar
^ lowered to one finger gap, I'd say you will be sunken by a thumb. I have the same offset in the back, but wider rims, 10'. You will most likely have to modify/remove the front fender liner. Fronts will be sunken by around 2 cm
Old 09-30-08, 09:17 PM
  #1958
Miami-SC
Miami-SC's Avatar
whats up guys! trying to figure out what tire size to get. i am going to lower the car pretty low and i want flushness if possible. the wheels are 19x8.5F +24 and 19x10R +40. i like the stretch look but not extreme.spacer size if possible too. thanks
Old 10-05-08, 02:06 PM
  #1959
ColtSwitch
ColtSwitch's Avatar
anyone running privat netz? Yes, I did a search.
Old 10-06-08, 10:59 AM
  #1960
craaaazzy
craaaazzy's Avatar
235 35 ZR19 Front
265 30 ZR19 Rear
decided on something else:
ccw 505a's.
19x8.5 front w/ 235/35/19
19x11 in the rear w/ 295/30/19
roll required to fit the rears.
Old 10-06-08, 04:32 PM
  #1961
silhoulex
silhoulex's Avatar
19x10 + 26 work vskfs, slight fender roll needed
Old 10-06-08, 06:33 PM
  #1962
mr2tosc4
mr2tosc4's Avatar
19x10 +26 all around? that looks very good!
Old 10-06-08, 06:41 PM
  #1963
mr2tosc4
mr2tosc4's Avatar
anyone...?
18 x 8 +26 is kinda like 18 x 9 +34, fronts will be sunk by a very little bit, can get away with no roll, my type of fitment.
18 x 9 +20 Rears definitely need rolling even with a slight drop.
Old 10-06-08, 08:55 PM
  #1964
VVhite
VVhite's Avatar
Looking for alot of advise. My goal is to make no fender mods with no rubbing but the offsets for the wheels I want are limited. Also suggestions for tires? Will this work and look OK?
18x9 front offset +30
18x10 rear offset +40
Old 10-06-08, 09:03 PM
  #1965
Kaydee
Kaydee's Avatar
check my sig, it should look somewhat like that...although your fronts stick out just a tiny bit
you will need a slight roll in the back if you do decide to lower it
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
