Fuel pump
Old Jun 24, 2007 | 06:34 PM
menappi's Avatar
menappi
Default Fuel pump
Anyone know where the wires to the fuel pump are, and which color is the power wire? Looking to put a switch on it as a fuel kill but don't know where it is, also is there an online version of the service manual?
Old Jun 24, 2007 | 06:37 PM
neurocity's Avatar
neurocity
Not quite my tempo
Fuel has to do with the Engine....Right?
Moved
Old Jun 24, 2007 | 08:19 PM
JspecSC3's Avatar
JspecSC3
Im pretty sure the fuel pump wires are attached to the fuel pump are probably inside the fuel tank located right behind the upper part of the back seat. If you pull out the upper portion of the back seat you'll see a round metal cover which holds the fuel pump. Be extra careful when playing around in that area.
If you are trying to cut the fuel with a switch as a form of anti-theft I would suggest going a different route with another option. My car is a push start. No key, no start.
Old Jun 24, 2007 | 10:58 PM
menappi's Avatar
menappi
You mean push button start? I was going to do that also, can you pm me some info. I also want to do a fuel kill and on my honda I just hooked a switch on the fuel pump power, but I don't know if that will work on the sc, and I couldn't find a DIY anywhere on hwo to do it. Maybe if I get some help I can write one up.
LoveSCs
Nov 4, 2021 11:41 PM
Trucho
Jan 1, 2021 01:29 PM
SC300_704
Nov 12, 2012 06:51 PM
whiteysc
Aug 1, 2011 02:41 PM
