SC- 1st Gen (1992-2000)
93 and 95 airbag swap = airbag light
Old 04-04-07, 08:12 PM
Eggman
Eggman's Avatar
Default 93 and 95 airbag swap = airbag light
should swapping airbags (both driver and passenger) between a 93 SC 300 and a 95 SC 400, be a problem? i thought it would be a straight swap. well, now i'm getting the notorious airbag light
Old 04-04-07, 08:50 PM
chanh55
chanh55's Avatar
You might wanna do a search for resetting the airbag light. I think there's something out there. Goodluck!
Old 04-04-07, 09:12 PM
SFFD785
SFFD785's Avatar
I doubt you will have a problem. They wouldnt make diffrent airbags for different years. I could be wrong, but im almost a 100% im right.
Old 04-05-07, 12:08 AM
Eggman
Eggman's Avatar
you mean this one, https://www.clublexus.com/forums/sho...d.php?t=115040 ? yeah, i read that. its only for code 22. i've got code 14 or 54 or both
well, arent the newer ones (97-00?) dual stage?
Old 04-05-07, 05:30 AM
aliga
Former Sponsor
aliga's Avatar
they the same, did you disconnect your battery before swapping?
Old 04-05-07, 08:30 AM
Jonathan o
Jonathan o's Avatar
Post
I don't think he did.
Old 04-05-07, 09:10 AM
Eggman
Eggman's Avatar
nope
so what damage did i do now?
Old 04-05-07, 09:50 AM
SFFD785
SFFD785's Avatar
Originally Posted by Eggman
nope
U need to get a reset tool and reset the codes. I did this on my M3 and it cost me a 100bucks to reset, but I was dumb and went to the stealer ship. Any good shop around your area will do it for around 40bucks.
Old 04-05-07, 09:57 AM
Eggman
Eggman's Avatar
that doesnt sound so bad. maybe i'll just buy the scanner thingy. thanks.
Old 04-06-07, 10:19 AM
Eggman
Eggman's Avatar
mechanic said on obd1 scanners wont clear the airbag light. said there must be something wrong with the airbag modules or wiring. recommended me to visit the stealership
Old 04-07-07, 01:16 AM
Eggman
Eggman's Avatar
the wire method finally worked!!!
this time i bought a switch and ended the sequence with no wires grounded. everytime i ended it with Tc grounded, the light would come back on. woo hoo. finally. i must have tried 20 times. thats gotta be a new record
Old 04-23-07, 09:51 AM
boobstar
boobstar's Avatar
a 97 sc300 to 97 soarer air bag should present no problems either, correct?
UCrazyKid
IS F (2008-2014)
18
03-19-19 02:25 PM
Babak
11-03-17 02:02 PM
REMON2020
09-14-17 01:01 AM
Chungstyle
Performance & Maintenance
02-17-06 12:25 PM
Quick Reply: 93 and 95 airbag swap = airbag light
