quick question on a 1jz in a sc
ok i just blew my headgasket... just curious on a 1jz swap. is everything bolt on to the car i got a W85... can i make my a/c to work. (i've done that to my SR20 for my 240s.) what is necessary for the swap? my tried searching but the search doesnt work.
Yes, you can keep your A/c, and yes you can use your w58. Just make sure u use ur existing flywheel. Everything bolts up, but there is some wiring. Make sure u get a soarer 1jz, itll make everything quite a bit easier
^^^^ What he said. Check www.clubna-t.com there's a full write up there. If you're done SR swaps you'll do fine.
Cannonbear
Nov 9, 2006 11:35 PM
You could put a 1J in a 240 though
