ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   can't open doors (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/252537-cant-open-doors.html)
zay386 Dec 6, 2006 08:18 AM
can't open doors
i have a 93 sc 300 and both doors cannot be opened from the outside but i can open them from the inside is this an electical problem? and does anyone know how to take the inside door panel off?
sliva001 Dec 6, 2006 08:24 AM
To take the inside panel, pry off the cover in the inside door opener, it will reveal a bolt in there and there are two bolts under the arm rest too, and undo the rest of the bolts. The panel should come off with the use of a pry tool or flat head to undo the locking clips from the bottom working your way up.
zay386 Dec 6, 2006 08:28 AM
thanks all i need to know now is how do i figure out this door handle problem have u had this problem before?
sc250tt Dec 6, 2006 08:30 AM
the rod is probably broken u just replace them .they are pretty expensve though
zay386 Dec 6, 2006 08:33 AM
damn thats for both doors.
PsiQo1 Dec 6, 2006 09:59 AM
90% chance its that stupid lil plastic clip that hold the metal rod to the outter door handle..i had this on my SC and i jus went to a junk yard and got a new one ... ill do a quick search and see if i can find a part number so you can see wat im talking about
Edit - here a diy on wat i think it is
https://www.clublexus.com/forums/sho...or+handle+work
