heater problem
Old Nov 22, 2006 | 06:47 AM
99navette's Avatar
99navette
Default heater problem
i tried to use my heater this morning and it would not get hot. my climate control works well i think it does. it shows the numbers changing to max hot etc. with the a/c on and with/out the a/c on it does not get hot.. what would be the problem.??
Old Nov 22, 2006 | 06:52 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
start by checking your coolant level. If that's fine, then it may be your heater control valve.
Old Nov 22, 2006 | 08:57 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Start by checking your search button.
This is so common any search would have yielded results that would help.
Old Nov 22, 2006 | 12:09 PM
chingpo05's Avatar
chingpo05
make sure the AC button is turned off and let your car warm up........ i don;t know lol
Old Nov 22, 2006 | 12:21 PM
yelloa3gti's Avatar
yelloa3gti
i am having the same problem. can drive the car for an hour and no heat.. then its weird.. like 1 out of 10 times it will work? who knows? i need to search it too cause its getting damn cold out
Old Nov 22, 2006 | 12:57 PM
jgdynamics's Avatar
jgdynamics
made me laugh, hahaha
but yea i got the same problem
Old Nov 22, 2006 | 02:23 PM
jgdynamics's Avatar
jgdynamics
wlel, i just did the HEATER VALVE HOSE SWITCHEROO and didnt work... would this mean i need a whole new heater control valve?
Old Nov 22, 2006 | 02:50 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Have you topped off your coolant? (even though I know you'd have seen this suggestion in other threads )
Old Nov 22, 2006 | 03:25 PM
yelloa3gti's Avatar
yelloa3gti
i too just didnt he vacume line switch.. still no heat .. and totally full coolant
Old Nov 22, 2006 | 03:45 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Well, let me tell you something ya don't know know yet.........
As long as your car is not overheating (stuck thermostat), then you are not full on coolant or you have not properly opened the heater core control valve.
There is NOTHING else to stop the flow of coolant. Heaters are REEAAALL simple.
RalAegidius
Nov 13, 2012 12:22 PM
Sid Ellner
Jun 8, 2009 02:41 PM
ShiftyD2k
Jan 22, 2009 12:34 PM
Tag129
Oct 4, 2005 11:47 PM
Baby ///M3
Dec 20, 2004 08:34 PM
