really need you tech guys input ...
Old Jun 15, 2006 | 10:55 PM
dubstar's Avatar
dubstar
Default really need you tech guys input ...
well, i had posted a couple days ago a problem with my car idling and thought it might have been the idle control valve, well, that wasnt the problem. i replaced the whole throttle body with one off of a friends. after the new one was put on, car started find and idled a little high actually. after a short test drive, the car kinda started to sputter a bit and then just cut off on me when i came to a stop. another thing is when you go to start the car now, there is a smell coming out of the exhaust, its def. running rich, but something else i cant quite place. if anyone has any suggestions or maybe had similar problems, please, let me know. thanks.
Old Jun 16, 2006 | 06:54 AM
ted17's Avatar
ted17
i had a simliar prob and i ended up replacing the tps, iac, and grounding cables none worked after reading a post on here i decide to replace the fuel pump ecu and problem solve.I just got a use one for like 40$.i had a simliar prob and i ended up replacing the tps, iac, and grounding cables none worked after reading a post on here i decide to replace the fuel pump ecu and problem solve.I just got a use one for like 40$.
Old Jun 16, 2006 | 07:47 AM
Dx3's Avatar
Dx3
Are you a parrot?
Jonny
Old Jun 16, 2006 | 07:57 AM
onebadshot's Avatar
onebadshot
Originally Posted by Dx3
Are you a parrot?
Jonny
hahahahahah
Old Jun 16, 2006 | 02:01 PM
ted17's Avatar
ted17
lol you got me....
91SHOman
Apr 16, 2021 04:01 AM
Spence1978
Nov 8, 2014 07:23 AM
supafreeza
Sep 30, 2009 11:19 AM
TroySC300
Aug 21, 2008 06:28 AM
daelo74
Apr 21, 2007 08:25 PM
