S-AFC settings on 1JZ swapped SC's
Old May 18, 2006 | 07:46 PM
CheryRd1JZ's Avatar
CheryRd1JZ
Default S-AFC settings on 1JZ swapped SC's
I currently have an S-AFC on my 1JZ swapped SC300. I believe that someone messed with mine recently at a car show and my car is acting funny. I was wondering if anyone could kind of guide me through how theres is setup. Info such as throttle point, in/outs on pressure settings, hi throttle settings and lo throttle settings. So far I've managed to run across a 1JZ DP and i'm getting a place welded in for a wideband sensor so that it can be tuned more efficiently.
Old May 19, 2006 | 03:14 PM
5spdSC300's Avatar
5spdSC300
If you zero everything out, the car should run like stock. Once you get a wideband, you can dial her in.
blueboost6
Oct 2, 2011 09:23 PM
nate579
Apr 21, 2009 03:59 PM
SC3005SPD1
Jan 30, 2007 08:58 AM
Mwmorph
May 5, 2006 12:06 PM
