ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   is there a writeup for Driver's Window replacement? (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/208755-is-there-a-writeup-for-drivers-window-replacement.html)
flyhigh123 Mar 29, 2006 05:03 PM
My driverside door window motor/regulator broke. Does anyone have a writeup on how to take apart the door to replace that unit?
Much help is appreciated.
mikeloc24 Mar 30, 2006 12:58 PM
I see you've been a member of this forum since 2004. Then you should know all about the search feature on this site. Enter some key words in the top left corner of this screen, read the threads, and you'll have your answer to this commonly discussed topic. I would do it for you, but then you'd never learn to help yourself. You can do it, good luck :thumbup:
hint: try keywords "window regulator" and look for a thread by O.L.T.
flyhigh123 Mar 30, 2006 01:11 PM
as you know that i'm an older member, than you should have assumed i already tried the search function, and with that i didn't find a write up... if i did find a write up then i wouldnt have posted...
found it thanks
https://www.clublexus.com/forums/sho...ndow+regulator
mikeloc24 Mar 30, 2006 01:34 PM
found it thanks
We are trying to cut down on the amount of repetitive informationless threads in the SC section of the forum. The problem you're having is perhaps one of the top 3 MOST commonly discussed topics on this forum in terms of common problems on the SC and a simple search would yield a ton of information. But now if someone searches for the same thing you needed they will come across this thread which doesn't contain any DIY info, do you see how this can be a little problematic and only adds to the number of non-helping threads in the database?
No one is coming down on you because we all try to help each other here, just saying to try finding other options before simply starting a thread on a beaten to death topic.
flyhigh123 Mar 30, 2006 03:18 PM
i know its a common problem... the thing is i did a search, i guess wrong words, and went through 3 pages and didnt really see anything...
RGW LLC Mar 30, 2006 07:30 PM
you got PM..
