Bolt On Mods
weight reduction? have you done any suspention mods? brakes? tires? did you replace the radiator fan with a eletric fan? (seen here : http://intellexual.net/faq.html#027) LSD?
What kind of mods can I do to my auto sc300 that you think it will make a difference? (no turbocharge please). Is has 100shot nitrous already, a Greddy cat back exhaust and Injen Intake. It is 1993 and have 68K miles. Thanks
Originally Posted by NYLexSC
Do a full tune up if you haven't recently. Change your oil, plugs, wires, cap, rotor, flush out some fluids, etc. It will make a world of difference.
The Answer:
1. Get Bigger Injectors
2. FPR w/ Fuel Rail
3. Ignition w/timing retardability
4. Nitrous Cams
5. Thin HG to raise compression or High Compr. Pistons
6. Valve Springs and Retainers
7. Raise your rev limit.
8. Air Intake System
9. Full Exhaust System (at least 2.5")
10. Up that shot of Nitrous to 125
11. Headers
12. Spend some dough tuning the car.
2. FPR w/ Fuel Rail
4. Nitrous Cams
11. Headers
Originally Posted by neuro4you@
That is the way to go...I thought of doing the Modded out NA thing....too much work for little power.....
get the hairdryer on there
For under $2000, u can run mid 13's with a simple motor swap (and u get a motor that has nice low miles on it)
