[pics] Lowering: Stock vs SC Eibach vs Supra Eibach
Old Apr 26, 2006 | 05:47 PM
  #31
BLK13X's Avatar
BLK13X
For Mind Cruising
The only thing I didn't like about the Espelirs is that they bottom out when running OEM struts. That's the set up I had in my old car. The ride was very soft which was nice but I would've preferred a stiffer ride.
Old Apr 26, 2006 | 05:56 PM
  #32
np20412's Avatar
np20412
I've heard that as well. My stock struts had 100k miles on them, that's why I went ahead and swapped to Tokicos at the same time. I have a stock strut on my left rear still, with Tokicos on the other 3 because of a mishap with installation (basically Tokico sent me a broken strut). That left rear sits about 1/8-3/16" lower than the right rear does.
Old Apr 26, 2006 | 08:15 PM
  #33
blknfury's Avatar
blknfury
with running either the espiler or tt eibachs is their a need for the camber modification or any other adjusment if you were driving on 18's?
Old Apr 27, 2006 | 05:24 AM
  #34
np20412's Avatar
np20412
It's hard to say. It depends on a number of factors as to what your degree of camber will be. It depends on tire width, rim width, rim height, which struts you are using, etc..
I'm on 17x9 (255 tire) in the rear and 17x8 (245 tire) in the front, and I have NOT used a camber kit with the Espelir + Tokico combo. Some members who have dropped on this combo DID require the camber kit. Your best bet is to just do it and then see where you sit camber wise.
Old May 14, 2006 | 07:41 PM
  #35
akitamike's Avatar
akitamike
Default For the Northern California Guys, what suspension shop
do you bring the SC to for work? I recall there was a place down south in San Jose that everyone uses? Thanks, I've been trying to find it by reading posts but I'm out of time right now b/c of kid stuff. Anyway to reply with the name of the shop to akitamike@yahoo.com, thanks much.
Mike
SC400
Old May 16, 2006 | 06:57 AM
  #36
scsrock's Avatar
scsrock
Thumbs up
Your "spring setup" discussion is very helpful!
xspsi6
Jun 15, 2015 01:04 PM
OneJay
Jul 11, 2010 09:01 AM
TheRonTom3
SC400 / 300 Classifieds
Feb 10, 2010 07:10 AM
CyberSC4
Apr 4, 2005 05:58 PM
