SC300/SC400 Tein Basic Coilover Kit ?
Originally Posted by DoubleWhoosh
CS for that chassis are not stocked in the US anymore, they are special order only. Figure around 4 weeks or so. They will be discontinued soon as well, so if you want a set you should order them asap.
Not much else you can do about it unfortunately
Well, the CS line is being phased out across the board, I guess the overall demand is not as high as they'd like, plus the design is on the expensive side to make so they are consolidating costs and models.
As I posted, you can order them now and wait for them, but that's about all you can do. Plus the longer you wait, you run the risk of them running out of them too, as they are not in production anymore, and the only ones left are what's left in inventory at Tein Japan.
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust.
