headlight adjustment
Old May 23, 2001 | 12:12 PM
flm's Avatar
flm
Question
can anyone tell me how to adjust my headlights??
Old May 24, 2001 | 06:48 AM
Whitmanpc1's Avatar
Whitmanpc1
Lightbulb Headlights...several mechanics and no solution!
I do not know how to adjust them, and since an accident years ago my driver's side lamp doesn't point correctly.
Several mechanics, none know how. Time to go to Lexus!
Old May 25, 2001 | 04:23 AM
stoplight's Avatar
stoplight
There is a metal hex headed (about 10mm) shaft and a black hex headed shaft. One does the side to side and the other does up and down. The metal one is silver and all of the way to the outside of the car just in front of the airbox or battery. The black one is on the back of a calibrated clear plastic cylinder directly behind the leveling bubbles but also in the engine compartment. The high beams have similar adjusters but are in the nose in front of the radiator.
Old Oct 11, 2002 | 01:42 PM
NAZTY97's Avatar
NAZTY97
Default which is which???
I saw the black one last nite, and didn't fool with it. I think I need to lower my beams,...I noticed my bubble a good bit forward of the 0 marker. When my fog lamp was burned out,... I drove with both off, and didn't think I was gettin' enough light to the ground.
What is the the correct setting? Dead center at "0" I would imagine?
soulific
Apr 12, 2010 05:29 PM
novak82
GS - 1st Gen (1993-1997)
Nov 27, 2007 03:43 PM
ajbboi
Feb 9, 2007 12:07 PM
Jubane
RX - 1st Gen (1999-2003)
Nov 5, 2005 02:45 PM
blux
Lighting
Aug 21, 2002 03:35 PM
