I'm an amazing idiot, TRAC donuts
Mortgage Slave
Hahahahaha
Thank the Toyota Gods for the Soarer 2.5GT!!! lol... no traction control (only optional... and mine doesn't have it lol)... no worries losing it in the wet Can get the rubber smoking though
Originally Posted by DlaxMan3
correct me if im wrong but i don't believe you can do a break stand in the SC cuze it has 4 wheel breaks ,a break stand i when you apply the breaks if you have 2 in the front or the back and you hit the gas and the wheels without breaks spin while you stay in place.
I always thought a brakestand was powerbraking, hitting the brake and revving up the engine to power launch.
What you described Dlaxman3 is a burnout, and most of the time it is 4 wheel brakes but the engine has so much freakin torque it just overpowers the rear brakes and the fronts hold the car in place or you inch up a little bit.
Originally Posted by LexSC888
works on my SC, i avoid doing it because not only does it sound awful for all kinds of parts, it is awful. I can get the rear wheels spinning (together most of the time, on one occasion i only got the rear left to spin while the rear right did nothing ) without moving anywhere until i hop off the brake.
Zombie Slayer
Ummmm....I hope you mean 4 wheel disc B-R-A-K-E-S. When you say two in the front or back, you do realize that there would still be B-R-A-K-E-S on the other wheels also, only they would be drum B-R-A-K-E-S. Regardless, doing a "brake stand" or "powerbraking" will always work if the car's engine creates enough torque to overpower the B-R-A-K-E-S. I believe all SC's have 4 wheel disc B-R-A-K-E-S but they are capable of still breaking the rear loose with the brakes applied.
Nuetrol droping? OMFG DO NOT DO THIS!!!! You are asking for a new transmission its 5x worse then shifting a manual without using a clutch. Think its spinning at 6k RPM and then all of a sudden you JAM it into D and the gears and rearend quickly have to react grinding down teeth and ALOT of stress on the whole drivetrain. My brother did this 3 times and the 4th his tranny went out! If you do it you mys well take the price of a transmission and throw it down the toilet and I gurantee the automatics are NOT cheap especially the new 5 speed automatics . If you want to do a burnout (still not recommended but DEF. not even close to as hard as a N drop) put your foot on the brake the whole way and give it some gas to get it spinning but don't take it over 5 (I know its not that high) but when you rev the car freely / spin freely without a load it's very hard on the engine!
Edit: Toyota trannies are pretty strong but I still wouldn't recommend doing N-Bombs. If you want to burnout, get an LSD and torque converter upgrade.
Zombie Slayer
EXACTLY!!!!!! The only thing worse than a neutral drop for your tranny would be to use sand as tranny fluid!!!
Originally Posted by DarchMage
Yea that's a big no,no. At one point I was gonna scrap my tranny on my 92 Celica because I was going to get a manual swap. So I decided I would try to burn the tranny. Neutral bombs, throwing it into reverse and than drive really fast. Nothing would kill this tranny.
Personally I have never wanted to abuse my car by doing a brakestand, donuts, or any other trick that involves burning up my $100 tires or causing my transmission to leave gear teeth all over the road.
My 1992 SC3 doesn't have traction control -- I don't believe it was available back then. It makes the rear end squirrely unless you have good tires and you're accustomed to a RWD car.
I have an SC400 so I cant be to sure about the 300, but they did have T/C as an option at that point (SC400). As a matter of fact my SC came fully and I mean fully loaded; the car has moon roof, optional rims, Nakamichi soundsystem, T/C heated seats as well as the optional up holder, thats right, I got the cup holder, lmao (never installed it). If you N-drop you will regret it, my friend now has to repair the transmission in his nex Mazda 6, lol, was wondering how he got the thing to rev while standing at the light in his auto (still gave it to that piece of wood).
Old fart advice
Originally Posted by Dx3
HAHA - that's funny, the last thing I read about was you saying the car is your dad's, then I read you are doing burnouts and 360's!!! Hope your dad doesn't read CL!!!
Yeah, no trac makes for fun times. Put the car in N, rev it and drop it into D and you can do a hell of a burn out!! I used to do it in my Infiniti all the time. Try not to do it in the Lex!!
Peace,
Jonny
Peace,
Jonny
Eedo123
IS F (2008-2014)
03-19-16 10:11 PM
