BFI underway... need help with decisions
Old Dec 30, 2004 | 03:52 PM
SCV8's Avatar
SCV8
I suppose if it were done effectively, very well sealed so it didn't just wind up holding the heat that was gradually collected, it would give you some additional timing that otherwise wouldn't be there. Still won't keep the ecu from the retarding during shifts that our cars do.
I've looked at re-locating the MAF to keep it cool, but it's in a pretty good place already.
Old Jan 4, 2005 | 04:55 PM
ONe21's Avatar
ONe21
I don't think I'm going to mess with the MAF, that wouldn't end well.
I got another idea for the "ram air" modification that might work well (I'll let you decide). You know that flex pipe stuff that looks like the hose that comes out of the back of a dryer, well I found some 3" rigid flex pipe that might work. You could make it come from the air box and down to the front air dam. I'll have to measure that square cut out in the frame to the right of the head light to see if 3" piping would fit through it. Another concern would be that it wouldn't flow well, because it has ridges.... and that would obviously not flow as well as a flat surface.
I still haven't broken ground, because I want to fully explore my options. I think I may just go with BFI 3, without the egg cups or whatever.
MouthOfWar
IS F (2008-2014)
Aug 8, 2013 08:34 PM
Nigel-JDMParts
Club Lexus Vendor Marketplace
41
Mar 1, 2011 05:24 PM
b2designs
Aug 26, 2010 09:00 AM
Evitzee
Aug 17, 2010 11:24 AM
