Climate Control PROBLEM...
Old Oct 11, 2004 | 04:52 AM
aeropartz's Avatar
aeropartz
Default Climate Control PROBLEM...
Is my Climate control BROKEN?
AC works, Heat works, Fan works,.... BUT I have to keep the temp at COLD for it to blow any cold air... once its set 65 and up... it blows HOT air
What is the problem? How can I fix this? What can be wrong?
Old Oct 11, 2004 | 09:57 AM
TeeDub's Avatar
TeeDub
What does the outside temp read? -22F would be my guess.
(Do you have that option next to the trip odometer?)
Old Oct 11, 2004 | 10:02 AM
aeropartz's Avatar
aeropartz
I have a 92 Sc400, it doesnt show the outside temp...
Old Oct 11, 2004 | 10:45 AM
/Aerostar\'s Avatar
/Aerostar\
ahh yes, yet another VSV problem. Its this little black expensive thing that manually controls wether or not you get hot air, cold air, neither or both
do some searches for "VSV"
Old Oct 11, 2004 | 11:19 AM
aeropartz's Avatar
aeropartz
I did a search on the VSV,
The only difference in problem with the VSV, is that I get HOT air... its only HOT or COLD that I get.. nothing in the middle...
Do you think its the same problem?
Old Oct 11, 2004 | 01:07 PM
LexAnt's Avatar
LexAnt
here's a cheap fix... or actually a couple
1. check to make sure ur coolant is topped off
2. look at the pcv valve... make sure the hose is snugly connected, i had the same problem, only the problem was the hose kept coming lose... a hose clamp fixed that... should be on the passenger side towards back of engine bay... it' looks like a little cylindrical thingie
Old Oct 11, 2004 | 01:16 PM
aeropartz's Avatar
aeropartz
Coolant is topped off...
I will take a look at the PVC, can you give me a more detailed location...? of the PVC valve...
Old Nov 20, 2004 | 02:40 PM
aeropartz's Avatar
aeropartz
Default PVC?
i cant find it, can someone help?
Old Nov 20, 2004 | 05:49 PM
aeropartz's Avatar
aeropartz
Thanks for the link... my PVC (I located it with your link) is leaking but not so much... I cleaned it to see if it will leak anymore...
But my heater problem still going on...
Old Nov 20, 2004 | 06:02 PM
aeropartz's Avatar
aeropartz
I will do that.. thank you
Old Jan 4, 2005 | 10:04 AM
Salil022's Avatar
Salil022
i am having the same problem guys my climate control unit will only blow hot air regardless if the temperature is set to 65 and if its set to max cold only then it will blow cold air noting in between let me know what do i need to replace
thanks
Old Jan 5, 2005 | 06:31 AM
aeropartz's Avatar
aeropartz
Default This will help you..
https://www.clublexus.com/forums/sho...d.php?t=108682
Read this, it should answer all your questions
Old Mar 18, 2006 | 09:34 AM
Salil022's Avatar
Salil022
hello, i've read those instructions few times and i just replaced the VSV valve located near the canister over by the passenger side in the engine bay, and its still blowing hot air from 65 and up and blows cold only in max cold. what else could be wrong? is there any other valve that needs to be replaced?
Old Mar 19, 2006 | 07:45 PM
Salil022's Avatar
Salil022
anyone with suggestions?
Old May 13, 2009 | 03:56 PM
Hey Johnny's Avatar
Hey Johnny
Bump for fix
