TT transmission is dead
Originally posted by William N.
abboushi, I just pm Dave and he did change my screen name for me...thanks for telling me.
Now I am worried about my auto tt tranny. I have the stock sc300 diff also. I haven't ran into any problems yet. Hopefully I don't run into any soon..Good luck Chris..
William
William
That's what did it. I am 100% sure now. Look at this information:
92-00 SC300
6 cyl, AT (4.27 ratio)
92-96 MKIV Supra:
w/o turbo; (4.27 ratio)
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra:
w/o turbo; (4.08 ratio)
Taken from:
https://www.clublexus.com/forums/sho...ght=diff+ratio
I think you should be fine as long as you don't make any high speed runs. Guess I did a few too many. I'm looking for a used automatic Supra TT diff now. I hope I find one with LSD.
Chris
Chris,
Did you have the sub-throttle TPS working or did you eliminate it with the TRAC block off plates? Also, did your tranny just die all of a sudden or were there any symptoms before it happened(reving really high, having trouble shifting to a different gear, etc.) Good luck finding another used auto tt tranny...
thanks
William
thanks
William
Chris,
thanks
William
Chris,
thanks
William
Chris
Chris,
The sub throttle TPS sensor is located on the throttle body. If you looked inside your throttle body, there are 2 throttle body plates. The first one is the sub-throttle body plate(also called the TRAC plate) and the second one is the actual throttle body plate. A lot of people on supraforums take out the sub-throttle plate to increase air flow and then take out the sub-throttle TPS and TRAC sensor and cover it with the cover plates.
http://www.mkiv.com/techarticles/tra...fly/index.html
Also, when was the last time you changed your transmission fluid? If you've changed it recently, what was the color of it?
Chris,
Chris,
Chris
Chris,
Read this thread on supraforums.
http://www.supraforums.com/forum/sho...highlight=trac
this might explain why your transmission is dead..
Originally Posted by William N.
Chris,
Hows your transmission holding up. Looks like I burned mine up with the low ratio diff.
Chris
Originally Posted by DIrEctQL
It was all new fluid and it was fine. I actually had a Flex-a-lite cooler too. I belive they're disconnected. Why is that important?
Chris
Chris
Originally Posted by 90redsupra
NOt gonna read the links but, HEAT is going to be your number 1 destroyer. Keep your tranny cool atleast one good, fan cooled cooler.. When you remove the traction butterfly it will shift much harder, and faster cause the throttle plate never closer during shifts so its really rough on the tranny. I have Keans Th400 kit and love it BTW. -Brett
Chris
No doubt. Having a higher ratio rear end will make the transmission run hotter. That's what fried my first tranny.
Chris
Chris
It will wrap your motor up higher, just like driving around at a higher RPM. That in itself will not do anything to your tranny
Chris
Chris,
Sorry to hear that...More money and time down the drain. As for my transmission, I haven't had any problems with it, thank god... Stock differential too....I have one extra tranny cooler and thats it... Do you know if your transmission lines are close to the downpipe? I remember that mine were kinda close so I wrapped them with insulating material. Other than that, I don't know why you are burning up trannys...If you need anything else, just let me know...
William
William
do you always have to go TH400 or TH350? Does the adapter plate also fit a 700R4 or 200R4 (gn tranny)???? I like OD
If i had my wish, id do a built 7L60E with stand alone ECU computer, but i dunno if its possible for under 10gs lol
