what size turbo
Better for what??
The fact that you're asking this question says you need to STUDY and learn a bit about turbos!
I'd HIGHLY recommend you start by reading Corky Bell's book "Maximum Boost". When you're finished, you'll be able to answer all your questions
I dont now tomuch about turbos but i do now alot about car i am a master certified bmw tech. I would like to know wich one is bigger i want build a sc300 with 500 - 600 hp. Not sure what rpm yet.
), then you compute how much air it will take to burn that much fuel, and then and ONLY then, will you be ready to look at compressor flow maps to see which turbo will flow the amount of air you need. THAT's where you see what size turbo you need
Do yourself a BIG favor and study up on turbos before embarking on your buildup. You'll save a HUGE amount of headaches down the road
