i was just wondering if there is anything else i should do before i order my tubo kit?
i already have most everything u can get thats bolt on complete pulley kit cam gears flywheel stage 3 clutch exhaust crane ignition short shifter also brakes spings and shocks tower brace is ther anything else i should consider before the spool goes on? id love some advice!!!!!!!! especially about diffeentials and tanny's. |
sounds like you are ready to me!
Did you buy your short shifter??? or do something to it. Also are you using RPS's stage 3 clutch and flywheel.... What turbo kit are you going with, also are you planning on using the stock intake manifold or are you planning on getting a modified one made??? IF so let me know, I would like to speak to you about this. Email me privately if you wish Scot Hail 93 SC00 5 speed |
Got Boost?
go get it :D |
what turbo kit are you buying?.......boost is good
i was thinking about the f-max kit w/ the water injection and nos. but i still need to do some research on which one will fit my needs the best. it will probably end up being a mix!
as for the shifter it was just cut down, i pulle dthe idea from one of our own who said he cut and welded it, thanx, i cant remeber who it was though, but it works.... u should have it done while ur getting the clutch pulley and flywheel installed. and all the pulleys and flywheel are unorthodox w/ a vitek stage 3. |
i highly reccommend staying away from the f-max kit..there manifolds crack...and warp witch leaks boost and creates all kinds of problems.....toyomoto makes the best quality kit out there and there very high quality......scott hureau just did a toyomoto kit and was very happy with it...it also allows for any type of upgrade in the future you would like....scotts car at 10psi and stock compression is a hell of a fun car..i believe it went 12.80s @109 on street tires....:eek:
toyomoto has replaced many f-max manifolds and piping from the f-max kits due to poor quality work....email if you need more info id be happy to help...and so you know the watter injection is not needed and often goes bad |
what stage kit is he running? is there any info for the prices and diff setups they offer?
do u know anyone in northern va for doing the install? i apreciate all the help. |
in N. VA
i'm here in dc now for school, GW. there are a few stores around. I actually stopped by one this weekend in rockville, md. not too far. you should give me an email we can meet up or something.
Arthur |
im her in the dc area also. what place?
location location
i'm in foggy bottom.... i go to school at GW.... my car is at home..... but would love to get togethor for drinks or whatever.....email me wolfy187@aol.com
arthur |
scott is running a stage 1.5 turbo kit. he has a stage one with slightly bigger turbo and fuel pump. he is running a side mount intercooler and two additional injectors. he is somewhere on this board........hopefully he will chime in to give you more details and seat of the pants performance talk.......:p
