My really important issue - the cupholder!
Old Sep 5, 2010 | 03:32 PM
Cough's Avatar
Cough
Default How to remove console cover if your cupholder jams
2010 RX 350
For some reason the retractable top of the cupholders in the center console will not retract fully. It goes back about 95% but sticks across a little into the area where the cups/cans should be vertical.
I suspect something has fallen down which is stopping the top retracting fully (it is fine in the closed position) But I cant for the life of me figure out how to remove the lid and take a look. The lid hinges are quite flimsy so I am loathe to tweak it hard in case I break something. I hope this isnt a major dismantle of the centre console.....
See below for solution to problem - hope it helps others
Last edited by Cough; Oct 15, 2010 at 09:48 AM. Reason: To help people with a how to and now with pics
Old Sep 5, 2010 | 04:07 PM
Johnny's Avatar
Johnny
Mine did the same, on the first day - I couldn't even close it or open it fully! However, I figured something from the factory was put there to secure it in shipping, and whatever it was wasn't removed before delivery (my best guess anyway). So, I jiggled it a few times, and I heard something fall. After that it was fine; whatever it was is still in there.
The flimsiness is the buffered spring return, similar to the glasses holder, handgrips, etc...
Old Sep 8, 2010 | 10:43 AM
Cough's Avatar
Cough
The cupholder action has been fine until now. The issue of not fully opening is only recent. Can anyone help me with how to dismantle the lid or the console and get at the action??
Old Sep 8, 2010 | 04:13 PM
Cough's Avatar
Cough
Ok I found the problem. One of those thin plastic golf pencils had jumped over from where I guess it had lain inside the cupholder into the small gap between the lid and the INSIDE of the cupholder. Then it lay jammed underneath the lid just stopping it from opening fully.
I removed the console cover by carefully levering it up from end at the rear of the car (no screws hold it down). I had to unscrew the gear shift ****, then the whole cover lifted off easily. Reclipping it back in place was fairly simple but the harness for the heated seats controls came loose easily so I made sure that was plugged back in.
Old Oct 15, 2010 | 12:13 AM
Johnny's Avatar
Johnny
A similar event happened to me. A plastic knife managed to slip through between the door and the box. I asked for further instructions from Cough, which he graciously provided:
It was really quite easy. You have to lift the whole of the center console cover - not the beverage holder cover. basically from the gear **** to the leather arm rest/cover. The top of the center console ends just behind the temperature control for the heated seats - just in front to the leather lid for the center console junk/ipod compartment. Just pry it up gently there (it clicks in but doesnt take much force to lift it up). Then continue lifting the whole center console lid off...
That helped tremendously, and I'm attaching a couple of pics which illustrate the opening of the console. I would caution that tools are not needed to pry the console up - finger pressure is sufficient. Also, since the access inside the console box is quite restricted (I pulled the plastic knife with needle nose pliers through a tiny gap), dropping anything else like gold chains or very small objects will require the whole console to be removed. That will mean disconnecting a number of switches and the Navi haptic input device to do so.
Attached Thumbnails My really important issue - the cupholder!-sam_0724.jpg   My really important issue - the cupholder!-sam_0728.jpg
Old Sep 11, 2017 | 09:58 AM
F250's Avatar
F250
I know this is an old thread, but this is very helpful. Just this weekend, our lid would not retract back to the 100% open position, so I came here looking for "experience". The description and pictures are great, and I'll be sure to take care f this as soon as I get home this evening.
UPDATE: Yep... snapped out the console lid, and sure enough, that connector on the seat heater module certainly likes to disconnect itself while fumbling around with the lid. I also had to disconnect three additional lighting connectors in order to flip my lid sideways to extract the culprit -- a water bottle cap! Once all my other work settles down, I'm going to look into gluing in some sort of flexible shield to block the passage under the flip cover... something which would ride against the underside of the flip cover yet remain out of the way of cups/bottles being placed in the holder.
espressoRX
Sep 4, 2025 03:24 PM
BB1234556
LX - 3rd Gen (2008-2021)
Feb 1, 2021 11:00 AM
joelake1
Nov 9, 2015 11:14 AM
kitlz
RX - 3rd Gen (2010-2015)
Mar 6, 2011 03:14 PM
trcr1@gran
May 2, 2009 09:57 AM
