Dash symbol
Old Sep 1, 2023 | 05:07 PM
Steveg67's Avatar
Steveg67
Default Dash symbol
What is the yellow symbol on the lower left of the center dash that looks like the top of a car with a sunroof and circle around it?
i noticed them on loaner cars
i will add a pic when i can
Old Sep 1, 2023 | 07:33 PM
Bentru's Avatar
Bentru
Default Some definitions
Old Sep 1, 2023 | 09:35 PM
Steveg67's Avatar
Steveg67
Old Sep 1, 2023 | 10:14 PM
Bentru's Avatar
Bentru
My guess is for a Lexus year 2022 or less, that have the safety system 2.5 or 2.0.
The 2023 model have the new safety system 3.0
information ;
;This version, called by the manufacturer a Safety Support Indicator, is seen as a vehicle from above inside a circle, also in yellow/amber if one of the systems noted below is not functioning properly. The circle represents that the vehicle is protected all around from all sides. It may be seen in gray scale as well in the information display. The trouble may be as simple as snow and ice accumulated on or near the sonar sensors.
This version is also an outline of a car inside a circle, but appears in gray scale. The manufacturer in this case has the indicator appear when one of nearly a dozen assist system options is turned off. It is thus there to alert the driver to that fact.
Old Sep 2, 2023 | 12:00 AM
Steveg67's Avatar
Steveg67
So i had my car repaired at the bodyshop and one of the sensors under the headlight was damaged. They replaced it and had the lexus tech come out and reprogram the ultrasonic system but of course the servers for the system was down go figure
Old Sep 2, 2023 | 02:29 AM
ggebhardt's Avatar
ggebhardt
Originally Posted by Steveg67
Mine had just started showing this symbol a couple of days ago. After thinking about it, I think it is because I disabled the automatic parking brake. About the same time this appeared. I will be reactivating the parking brake today to see if this symbol goes away.
Old Sep 2, 2023 | 09:04 AM
ggebhardt's Avatar
ggebhardt
So this morning no matter how the parking brake was set the light remained illuminated. As I drove down my driveway and the front camera stopped and the screen went into map mode, the icon went out.
Old Sep 2, 2023 | 08:07 PM
thesemes's Avatar
thesemes
The safety system light was the last error message/symbol I saw in our rx. Never drove it again. Hope you fair better.
Old Sep 4, 2023 | 07:10 AM
Deeps1's Avatar
Deeps1
i think i have seen it if one of the doors isnt closed properly and while reversing out of the garage. once the doors are closed properly (they definitely need a bit more force than any other door i have tried )
Old Sep 5, 2023 | 06:43 AM
BCBrent's Avatar
BCBrent
I agree with the doors requiring more force then normal; I and other passengers have been caught not having closed the doors completely.
With the last RX 450H, I would tell my wife not to slam the doors, for it is not necessary. I no longer do that.
For some reason when we received the 500H, I was expecting self-closing doors; I probably got confused with another vehicle we had tested.
Old Sep 5, 2023 | 02:13 PM
ggebhardt's Avatar
ggebhardt
I think there is another symbol for the door not closed. It shows the car icon with one door open.
My warning icon did not illuminate today. Still think it was because of my disabling the Auto parking brake. For now no worries and am enjoying my 350h!
Old Feb 8, 2025 | 07:20 PM
oscargali's Avatar
oscargali
1st Gear
Pls make sure that your inside and outside sunroof it is completely close and that light will go away
Old Feb 8, 2025 | 07:58 PM
Raven67's Avatar
Raven67
I disabled my parking brake a week after I got the car over a year ago, that definitely not it. the only time ive seen it on our RX is when snow built up on front sensors.
Old Feb 10, 2025 | 09:32 AM
CommodoreAmiga's Avatar
CommodoreAmiga
I see this indicator occasionally when it snows or there is heavy rain and the cameras are partially covered. Sometimes the picture is still "good enough" for me to use the panoramic view monitor to park, but the system complains and will disable auto-brake and other safety features because of the dirty camera lens(es). Just one of I'm sure many examples when that indicator will illuminate.
n8than8
UX Models (2019-present)
Feb 15, 2023 09:52 AM
miop4000
NX - 2nd Gen (2022-current)
Jun 26, 2022 07:07 AM
shinjyo
GS F (2016-present)
Jun 21, 2022 11:10 AM
4litre
May 7, 2022 02:52 PM
kjv1611
Jul 11, 2014 01:06 PM
