Return to last setting after max cool?
Old May 30, 2023 | 12:28 PM
daryll40's Avatar
daryll40
Default Return to last setting after max cool?
So now that it's hot in Pittsburgh, I'm enjoying the "Max Cool" shortcut button. But I have a question: Is there a "return to what you had before" button? In other words, once you hit Max Cool, the car calls for "LO" (maximum A/C). Once the car cools after a few minutes, is there an easy "one touch" button that takes it back to the last setting under "AUTO". Say back to 72 degrees AUTO? Or must I manually turn up the temp control to 72 degrees, which is what I've been doing?
Old May 30, 2023 | 12:29 PM
Urlik's Avatar
Urlik
Hey Lexus, set temperature to 72. That should work, I haven’t tested it.
Old May 30, 2023 | 12:30 PM
daryll40's Avatar
daryll40
Yeah, that works too. About the same effort as twisting up to 72.
Old May 30, 2023 | 02:37 PM
ggebhardt's Avatar
ggebhardt
It is sad you have to look when adjusting the temp. A up and down button would be my preference or some kinds of feedback while turning the ****.
Old Jun 16, 2023 | 02:35 PM
Urlik's Avatar
Urlik
So just got back from a week’s vacation with the RX so it’s the first time I ever got into the car when it was scorching hot inside. I think you’re asking the wrong question daryll40. The question should be why the heck the car doesn’t automatically go into max cool to cool a very hot car down to your set temp quickly. Isn’t that the whole idea with auto climate control? Climate concierge on or off the RX seems happy to take an hour to get the car down to your set temp.
Old Jun 16, 2023 | 02:37 PM
daryll40's Avatar
daryll40
Very good point. Agreed
Old Jun 17, 2023 | 12:50 PM
Nibor's Avatar
Nibor
You can actually, by configure the custom touch buttons on the steering wheel (if you have the HUD). I have configure it so I can change temperature and AC / airflow control. It’s a very handy option. No need to use the dials anymore!
Old Jun 17, 2023 | 02:53 PM
daryll40's Avatar
daryll40
I’d love to see a video or photo
of this.
Old Jun 17, 2023 | 04:55 PM
Urlik's Avatar
Urlik
of this.
3:34 here daryll:
Old Jun 17, 2023 | 05:15 PM
daryll40's Avatar
daryll40
Thank you! But if I do
this, don’t I give up audio controls there?
Old Jun 17, 2023 | 05:29 PM
Urlik's Avatar
Urlik
The audio controls will still be on one of the two pages of controls for the left side. You can only modify the second page.
Old Jun 17, 2023 | 05:48 PM
daryll40's Avatar
daryll40
Thanks for this. I’ll play with it and see what happens.
EDIT: This was SOMEWHAT useful. You still have to re-manually set the temperature after CoolMax, and you still have to go into the screen settings to get to CoolMax. But it’s sorta useful to be able to adjust the temperature on the steering wheel. It would be nice to have a "CoolMax" shortcut button then a "back to whatever it was before CoolMax" shortcut button.
Old Jul 1, 2023 | 01:14 PM
lexusnyca's Avatar
lexusnyca
Where is the Max Cool shortcut button?
Old Jul 1, 2023 | 02:35 PM
Urlik's Avatar
Urlik
Hit climate on the bar near the bottom and you’ll see it.
Old Jul 2, 2023 | 05:54 PM
Carbuff2's Avatar
Carbuff2
Isn't the cold air quantity the same when EITHER the MAX COOL is selected, or the Climate Concierge is trying mightily to reduce the cabin temp?
The difference being that the Concierge will reduce the blower speed (and noise) as the temp comes into line...whereas the Max Cool setting will try to create icicles until you turn it off...
Have not encountered conditions to test this, so far. Waiting to hear from the Heat Island area owners!
