Parking Assist Issue with Bumper Bully
I have a new 2019 RX 350. I park my vehicle in an indoor lot with valet service. To protect my rear bumper from the, not so careful attendants, i use a Bumper Bully. With my new RX 350, I find that the car will not go in reverse without the automatic braking taking affect. (even if a disable Parking Assist and Rear Cross Traffic Alert). Are there sensors in the rear bumper? Any suggestions to solve this problem?
Unfortunately, your Bumper Bully covering two of the sensors located on the rear bumper and that's what's causing the issue. I don't know whether you can drill two large holes to uncover the sensors or not and still retain the integrity of the Bumper Bully.
Thanks, I figured that, but I thought by shutting off the BSM and Parking Assist it would help, but it didn't.
You probably need to turn off ICS, too (Intelligent Clearance Sonar).
ICS - Thats one I am not aware of. I will check it out.
It's a little picture of a car backing up to a cone, with a star over it. Right under the setting for park assist.
Isn't the whole point of ICS to protect the bumper?
Originally Posted by Usual
(Post 10466267)
Thanks guys for the help. Now I have a dilemma. The problem is my parking lot and the not so careful valets. When they are parking my car the lights, warnings, sounds, etc are sufficient to prevent touching/hitting another parked car. When they are moving another car, the Bumper protector would be the only protection for my rear bumper. Going to see if I can cut holes in the Bumper Guard to expose the sensors.
Instead of disabling great safety options, how about installing a tow hitch with a long bar ball mount? This is what I have.
PS Since you are probably in NYC, your "protector" does the opposite as people now freely slam into you since you are protecting their car as well :) |
How about drilling some holes in bumper bully, aligned with the ultrasonic sensors, so the sensors inform the drivers not to hit something. |
Originally Posted by Gino45
(Post 10465635)
That & Parking assist are 2 different features. |
Originally Posted by Cocal
(Post 10467672)
No it cannot be turned off as it is connected with the front as well. It's the feature that brakes for you in case of collison if you do not apply te brakes.
(Post 10467672)
That & Parking assist are 2 different features. To turn the ICS system on and off: 1. Press the menu button on the steering wheel 2. Scroll left once 3. Scroll to ICS (at the top) and select it 4. Choose Yes or No As seen in the image at right, the MID screen will display whether the ICS system is on (yes) or off (no). RCTA is different from the Parking assist. Parking assist relies on the dots integrated on the bumper, while the RCTA system relies on two radar sensors (same sensor used for BSM) on either side of the bumper (hidden under the corners of the bumper. The best piece of advice, thats time tested is, simply attach a towing ball at the back. Most people use that before the bumper buddies came to existence. Source: https://www.lexuslearn.com/ltc-asset...liveryTips.pdf |
If you have a tow hitch, you could use one of these bump steps https://www.weathertech.com/bumpstepxl/ |
