OEM Michelin, OEM Bridgestone Vs Other (merged threads)
#361
You also hear of anecdotes where the dealer is willing to swap out wheels on in-stock cars, so that's another grey area for the actual mileage. In any case, it's hard for me to see thread depth as evidence of different material being used in OEM/non-OEM tires.
Edit: Besides, Michelin (I can only find the Canadian site on my end) lists the 20" Premier LTX as having a depth of 8.5/32 from the factory. https://www.michelin.ca/en/premier-ltx.html; so your 8/32 reading when you got your car sounds about right... Defender LTX has stock depth of 10.5/32.
#362
I toured the RX factory in Cambridge, Ontario. They only pick a few cars to be sent to their test track in the back. The rest are tested on a dyno for a very short time. Nowhere does the link say anything about odometers being “reset”. That would be a gross violation of the actual new car mileage. Why is it so difficult to accept that manufacturers are buying cheap & less mileage worthy OEM tires vs. higher mileage warranted tires from a tire shop?
#363
I'm still not convinced the Michelin Premiers are any different whether they are installed at the factory, or the ones you find in the tire store. If we're going by anecdotal evidence, my old RX 350 came with the Michelins, and when I traded it in at around 55k km (35k miles), they were still perfectly fine and (I think) at least 4/32 tread left. Just because there's no "official" tire warranty on them doesn't tell me anything about the tires. Weren't there some people on here who managed to get Michelin or at least their dealership to do a retroactive warranty/rebate on the Michelins when they were worn out early?
#364
This is interesting, and I think new. Go to https://www.lexustirecenter.com/ Enter your relevant information, and you will see that the Lexus dealer tires now have tread wear warranties. 70K miles for Bridgestones, 60K for Michelin’s, and 85K for Goodyear’s. These are the same warranties offered at TireRack.
#365
#366
Did Lexus update their FAQ regarding tire warranties as well now, or was it always there?
https://lexus2.custhelp.com/app/answ...=190,1284,1291
To quote: "All tires supplied as original equipment on new Lexus vehicles are warranted by the individual tire manufacturer only, and not Lexus. Coverages by individual tire manufacturers may vary."
It kind of makes sense that Lexus doesn't do the tire warranty themselves since they have different sources for the tires. You might just have had bad luck with the Bridgestone representative, or else they changed their warranty coverage on the OEM Ecopias.
#367
GSFRX350 (05-15-19)
#369
Saying that OEM tires may have worn from testing - come on, yes maybe they are rolled a few times but not 1,000s of miles. Have a look a new cars in a dealers showroom, most still have the little rubber "tags" hanging off the tires on the tread section. Tires look virtually brand new often.
#370
The tire prices at my Dealership, for the V rated 20" Michelins run about $23 per tire more with the same warranty as at my local tire store. Every once in awhile, the Dealership has a tire special that saves you $100 on a set of four tires. That makes the prices competitive with the local stores. the Dealership gives you a two year road hazard warranty (not sure about the local store). My dealer has a very good service department. I also know that if there is a problem with the TPMS sensor, the correct part and setup knowledge is readily available. Think I will stick with the Dealer, however I might change from the Michelins to the 85K Goodyears.
#371
#372
Read my post again. Tire Tread Wear warranty is the same at the local store and the Dealer. 60K for the Michelins.
#373
Perhaps there is a mileage warranty on Michelin now, but there wasn’t one in November when I purchased tires. I checked & neither brand had a mileage warranty when buying from Lexus. That’s why I went elsewhere. No luxury car tire should ever wear out in 20,000 miles! All of my performance car tires lasted way longer than that! So how do you explain those of us that had both Bridgestone & Michelin & our tires were shot by 25,000 miles, even with regular rotations?
#374
#375
life of original factory installed tires
I purchased 2017 RX350 in Dec 2017, and am the original owner, this car has 16,000 miles, and two tires are showing tread less than 2/32. Is this normal to have tires with such little life?
