Jack lift height
Looking to buy a new jack to change tires and do oil changes for the 4RX. Anyone know the required lift height to get the wheels off the ground? My existing 14" trolley jack doesn't lift high enough. Any specific recommendations?
Have you tried adding wood block or even better hard rubber spacers to raise?
Originally Posted by Jiggz858
(Post 10017824)
A 14-inch lift jack sounds like a toy. Look for a floor jack labeled "high lift" - should have a lift of at least 20 inches which should be enough. More is better. I wouldn't get one less than 2 1/2 tons or less than about 24" inches of lift. I'll leave it to you to do the metric conversion! :) Don't skimp. A high quality floor jack can last a lifetime. I bought my high lift floor jack in 1980 and have used it hundreds of times - still good as new. |
Solid rubber lift pads are regularly used in jacking up autos either for additional lift or for protecting the under carriage. And yes it is dangerous especially if you do not know what you are doing. But then even use of jacks alone is dangerous. Remember, you jack and insert stands. DON'T EVER WORK ON A VEHICLE SOLELY ON JACKS ALONE. Or if $$$ is not an issue, the better way to do it is to get a 3-Ton high lift floor jack. And some of these high lift floor jacks also uses extenders which are not a whole lot different than lift pads. Of course, this is MHO.
Do not forget the jack stands!
(Post 10018149)
However, the purpose of rubber lift pads is to protect vehicle undercarriages or frame rails - not to provide additional lift. These also can split and collapse - particularly as they age and become brittle. Most vehicles made by Toyota over the past past few decades have designated lift points, designed to accept a floor jack, at the center front and center back of the vehicle. Your owners manual shows where these two lift points are located. I certainly agree that the only purpose of a floor jack is to raise the vehicle high enough to put it on jack stands. Always use wheel chocks when raising a vehicle with a floor jack. |
When you decide to do things yourself, the should, could and would will always be there. Maybe the best way to tackle this is to have the dealership or an auto shop do the oil change. It sure cost more $$$ but you can at least avoid the should, could and woulds. Regardless how good or licensed you are as a mechanic, the should, could and would will always be there whenever you decide to do things yourself. It's the gamble you have to take when you try to save $$$ by doing things yourself. Oh don't forget make sure it's on "P" and mechanical brakes are applied.
(Post 10018416)
Since you are from Alberta...just use some hockey pucks. No kidding, been using them to lift a Vette for years...I've even mailed some to my Southern friends that don't have access to pucks as easily as us Canucks!
