Blind spot in RX series-Is it bad?
Old 08-28-17, 05:01 PM
DBXL
DBXL's Avatar
Default Blind spot in RX series-Is it bad?
I know this has probably been discussed before, but is the blind spot in the back rear sides of the 2017 RX's a deal-breaker for those of you considering the Lexus's, or has it been a big problem for those of you who already acquired one? I am vacillating between the 2018 Volvo XC60 T6, and the 2017 Lexus RX450h f sport, but that darn blind spot keeps holding me back. Does anyone know a good car shrink?
Old 08-28-17, 05:41 PM
kent2174
kent2174's Avatar
I am 6ft, seat sits high, and have no issue.
I rarely look back anymore as I used to because of cam and all the sensors.
Old 08-28-17, 06:14 PM
s4iscool
s4iscool's Avatar
No problem. I admit that I've become highly dependent on the blind spot monitoring though.
Old 08-28-17, 06:17 PM
RGSW
RGSW's Avatar
One must check the "Blind Spot" symbols in the mirrors before changing lanes. They work great if you use them.
Old 08-28-17, 07:07 PM
Nail34
Nail34's Avatar
I certainly would not buy an RX due the limitations, if any, of the BSM. I have it on mainly because I like the RCTA. I see the BSM flash when I'm checking my mirrors but I do not use it as my primary lane change vehicle. If you adjust your mirrors correctly, there is no blind spot. I'm sure I'm in the minority, nothing new there.
Old 08-29-17, 02:18 AM
ggebhardt
ggebhardt's Avatar
My side rear view mirrors and BSM pretty well eliminate any blind spot for me.
Old 08-29-17, 05:32 AM
FastFord
FastFord's Avatar
I have no issue or close calls due to the rear blind spot. I don't really use the BSM on the 4rx. The 3rx seemed to be a little more in my sight line and I noticed it more in that vehicle. It might be that I am sitting differently in the 4rx? I tend to know what is going on around me as I check my mirrors constantly.
I find the A pillar more of a nuisance than the rear area. Making left turns at an intersection with pedestrians around is more of a problem...to me. People can get hidden in that area if you don't look around the pillar. Again maybe it's my sitting position.
I would not rule out the 450H due to the rear blind spot. Like any new to you vehicle, you soon adjust your mirrors and other safety features to make driving an easy and safe experience.
Old 08-29-17, 06:38 AM
jr4div2
jr4div2's Avatar
Originally Posted by Nail34
If you adjust your mirrors correctly, there is no blind spot.)
What he said 10X! Adjust your mirrors so if you look from far left to far right, when you move eyes from the left mirror to rear view mirror there is a slight overlap in what you see. Then from rear view to right mirror, again, there should be a slight overlap. If you do that, you will not have a blind spot. Trust me. I have a Ridgeline with no BSM and that thing, without the mirrors adjusted properly would give you a neck ache in heavy traffic.
Old 08-29-17, 08:51 AM
guxu
guxu's Avatar
I am 5'10" and I do not have any blind spot problem. The BSM works fine, while I still double-check using my own eyes. I still wish BSM would beep instead of just flashing.
Old 08-29-17, 09:16 AM
Nail34
Nail34's Avatar
Honestly, if it beeped I would turn it off completely. While driving in traffic on the freeway it would be nonstop beeping.
Old 08-29-17, 10:26 AM
ericsan13
ericsan13's Avatar
It's bad, I check the blind spot very lazily now. Almost as if it's muscle memory.
Old 08-29-17, 11:26 AM
guxu
guxu's Avatar
It will only beep when your turn signal is on. This post proves that Lexus BSM's flashing light is less useful and people may not even know that feature.
Old 08-30-17, 01:15 PM
mikemu30
mikemu30's Avatar
Received 2,572 Likes on 1,829 Posts
I'm with you on that I even turn my head every now and then.
Old 09-17-17, 02:02 PM
giovane
10th Gear
giovane's Avatar
I have the BSM but mine doesn't beep when turning signals are on and a car is on the blind spot... am I missing something?
Old 09-17-17, 03:20 PM
dchar
dchar's Avatar
It doesn't beep...at least on US-spec cars.
Quick Reply: Blind spot in RX series-Is it bad?
