how do you replace cabin air filter??
Old 05-28-17, 09:35 AM
aznkorboi
aznkorboi's Avatar
Default How to remove glove box to change cabin filter
Trying to change my air filter. All I need to know is how to remove this!!
i tried screwing it the other way, pulling it, pushing it in. My other car just had a hook and you just removed it.
It it makes the glove box open slow.
Old 05-28-17, 12:04 PM
mnemons
mnemons's Avatar
Page 598, Mannual
aznkorboi (05-28-17)
Old 05-28-17, 12:08 PM
aznkorboi
aznkorboi's Avatar
Originally Posted by mnemons
Page 598, Mannual
what the heck! been looking for that diagram forever! lol. I tried sliding it off... Hmmmm
As you can see from the photo the screw looking thing is blocking the ability to just slide off the damper. It looks all scratched up too. Like someone tried to do it before me.
Old 05-28-17, 12:52 PM
azinn
azinn's Avatar
Been there, done that!
You have to really pull/yank on it............................it will come off!
That groove on the end that looks like a screw head actually gives way while firmly pulling away from it.
Old 05-28-17, 01:49 PM
FlopTop04
FlopTop04's Avatar
You could put some electric tape on the jaws of a regular size pair of pliers and gently squeeze the tapered end of that damper stud, then pull off the damper. Better yet, if you can find the correct diameter of plastic tube, you could slide that onto the end of the damper stud to compress it while you pull off the damper.
Old 05-28-17, 02:25 PM
aznkorboi
aznkorboi's Avatar
haha ok i'm just gonna pull it out
Old 05-28-17, 09:26 PM
lexnewbi
lexnewbi's Avatar
Page 598, Mannual
The instructions forgot to mention to press the two tabs together to slide off the damper. I find using wooden clothes pin or a plier covered with a cloth works well to press them together.
The following 2 users liked this post by lexnewbi:
daddiojigg (07-20-23), Gibster (05-30-17)
Old 05-29-17, 05:39 AM
aznkorboi
aznkorboi's Avatar
that explains the scratches.... thank you!
Old 05-31-17, 12:57 PM
HenryNYC
HenryNYC's Avatar
I was able to pull the cabin filter out without completely removing the glove box. Once you have the glove box open. On the top, squeeze the 2 sides and it can open up another 2-3 inches while still attached to the dampers. It was enough to put my hands in to take the filter cover off and just pull the filter/tray out of it.
Henry
FastFord (05-31-17)
Old 06-01-17, 09:45 AM
aznkorboi
aznkorboi's Avatar
Didn't need plyers to open it up. I just pulled it out and it gave way. Nothing broke.
Now, as far as the filter size, this is what I researched:
871390E040
Only the online dealers have it.. For 30 bucks!
Some websites said this would fit:
FRAM CF10285
I can confirm that it DOES not fit. It is too short
If anyone knows anywhere to get the air filters cheaper that would be great!
Old 06-01-17, 10:43 AM
HenryNYC
HenryNYC's Avatar
871390E040
FRAM CF10285
For what its worth, I did buy some CF10285, not from Fram though, thinking it would fit but like you. I found it did not. As far as I can tell. Lexus changed the tray design and there is a guide in the middle of the tray that I assume keeps the filter in place and centered. This guide is actually flipped or the filter pleats are flip so it will not go in and sit in the tray (Pleats are up and down instead of side to side if you will or vice versa). I'm not about to hack this tray and remove this guide even though I have a dremel that take care of it easily. I'll just wait for Fram or someone to make one that fits properly. The CF10285 will just go in to the CT so not a completely waste of a buy for me.
According to Amazon, This one from Fram should fit. Is this the one you bought?
Amazon Amazon
Old 06-01-17, 11:59 AM
aznkorboi
aznkorboi's Avatar
https://www.amazon.com/CF10285-Fresh...ywords=cf10285
yup thats the one that doesn't fit!
Old 06-01-17, 12:04 PM
toyotaman7
toyotaman7's Avatar
The Cabin Air filter needs to be changed about 1/year. The vehicle cost is $40K US$+. Is that extra $10 per year really that much??
Old 06-01-17, 12:09 PM
aznkorboi
aznkorboi's Avatar
lol... you make a good point toyota man
Old 06-01-17, 12:37 PM
ericsan13
ericsan13's Avatar
I would say that it's more an issue of design or "nickel-and-dime"-ing. Why make previously compatible parts incompatible so you can squeeze out $10 for a brand known for ease of maintenance?
Quick Reply: how do you replace cabin air filter??
