Help with rim sizing
Does anyone know what the max rim width and offset that would fit on the 4th gen RX? Initially I though the factory option of 20x8.5 ET30 seemed pretty weak but after looking at the tire/ fender, it seems it's semi flush. I would think you can play with the offsets only by so much. It also appears that a wider rim may touch the rear spring carrier if the offsets arent high enough.
Can individuals with aftermarket wheels chime in please? I was thinking of a 20x9 ET30 since I want to put a bigger tire on the car. Thx!
I think the factory RX 20" wheels are 20x8 ET30. You will have no problems front or rear with a 20x9 ET30
There is also a 22" wheel thread that gives you some ideas if you consider 22" ??
https://www.clublexus.com/forums/rx-...d-threads.html
I use this tool to find out what works and where the wheel and tire sit...just type in your specs....
https://www.wheel-size.com/calc/?wheel1=235-55-20X8ET30&wheel2=235-65-18X7ET35&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
