Carista?
Anyone use this on a 4RX yet? I gave up on trying to get my dealer to change my LPSs! Actually, has anyone used the Carista app on a 4RX in Hawaii? My dealer claims that Hawaii cars are shipped with different "options". I'm 90% sure he was just feeding me bs so they wouldn't need to do it, but there is still a slight possibility he was telling the truth. Hawaii cars are shipped without any safety connect/sos button so that's why I'm still on the fence on weather or not to believe him.
*UPDATE* Got the Carista OBD2 adapter and.....as I thought....it works! Here's a little cleaner list for those that are interested in exactly what is programmable on the 4RX. The following settings were available specifically to your vehicle using Carista: Doors / Windows / Remote Blink turn signals when locking/unlocking with remote *YES* / NO Beep when locking/unlocking with remote *YES* / NO Volume of beep when locking/unlocking with remote OFF / 1 / 2 / 3 / 4 / *5* / 6 / MAX Beep when opening/closing windows with remote *YES* / NO Allow locking when a door is still open *ON* / OFF Warn (beep) when door can't be locked because it's still open *YES* / NO Warn (beep) when a window is still open when locking doors *YES* / NO Warn (beep) when sunroof is still open when locking doors *YES* / NO Panic function on remote *ENABLED* / DISABLED Re-lock doors automatically if you unlock, but don't open a door *YES* / NO Re-lock doors automatically if you unlock, but don't open a door within… 30 SECONDS / *60 SECONDS* / 120 SECONDS Unlock doors via remote *DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS Unlock doors via physical key *DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS Unlock doors via smart key (door handle button) *DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS Max number of consecutive lock/unlock cycles via touch sensor UNLIMITED / *2 TIMES* Auto-lock all doors DISABLED / WHEN SHIFTING INTO GEAR / *WHEN VEHICLE STARTS MOVING* Auto-unlock all doors DISABLED / WHEN SHIFTING INTO PARK (P) / *WHEN DRIVER'S DOOR IS OPENED* After locking with smart key, don't allow re-opening within… *0.5 SECONDS* / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS Smart key location to start car FRONT SEATS / *ANYWHERE IN VEHICLE* Open trunk via smart access button DISABLED / DOUBLE CLICK / *LONG PRESS* Open windows and sunroof by holding key in door lock ON / *OFF* Close windows and sunroof by holding key in door lock ON / *OFF* Open windows and sunroof via long-press on remote ON / *OFF* Open driver's window using single button press *YES* / NO Close driver's window using single button press *YES* / NO Open passenger's window using single button press *YES* / NO Close passenger's window using single button press *YES* / NO Open rear left window using single button press *YES* / NO Rear-left window single-touch-close *YES* / NO Open rear right window using single button press *YES* / NO Rear-right window single-touch-close *YES* / NO Passenger window single-touch-open from driver's switch *YES* / NO Passenger window single-touch-close from driver's switch *YES* / NO Rear-left window single-touch-open from driver's switch *YES* / NO Rear-left window single-touch-close from driver's switch *YES* / NO Rear-right window single-touch-open from driver's switch *YES* / NO Rear-right window single-touch-close from driver's switch *YES* / NO Open/close power rear hatch via interior switch (click type) SINGLE CLICK / *LONG PRESS* Beep volume while opening/closing power rear hatch LOW / MEDIUM / *HIGH* Beep when starting to open/close power rear hatch *YES* / NO Beep while opening/closing power rear hatch *YES* / NO Beep type while opening/closing power rear hatch TYPE 1 / TYPE 2 / *TYPE 3* Unlock via "One motion" REAR HATCH ONLY / *ALL DOORS* Open rear hatch via "One motion" remote DISABLED / SINGLE CLICK / DOUBLE CLICK / LONG PRESS / DOUBLE CLICK ON UNLOCK BUTTON / *LONG PRESS ON UNLOCK BUTTON* Rear hatch open assistance *ENABLED* / DISABLED Rear hatch close assistance *ENABLED* / DISABLED Power rear hatch emblem sensor OFF / POWER OPERATION ON, EMBLEM SENSOR OFF / *ON* Power rear hatch emblem sensor sensitivity LOW / MEDIUM / *HIGH* Rear hatch max open level 1 / 2 / 3 / 4 / *5* Auto fold side-view mirrors (req. power folding mirrors) *WITH IGNITION* / WITH DOOR LOCKS / DISABLED Lower passenger-side mirror when in reverse gear DEFAULT / *USER-SPECIFIED* Instruments / Display / Dings Engine start indicator *ON* / OFF Display odometer after ignition is turned off for… *30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF Ding when headlights are left on *YES* / NO Seat belt warning ding (driver) *ENABLED* / DISABLED Seat belt warning ding (front passenger) *ENABLED* / DISABLED Seat belt warning ding (rear passengers) *ENABLED* / DISABLED Turn signal click volume *LOW* / MEDIUM / HIGH Lane-change turn signal auto-flasher count OFF / 3 FLASHES / 4 FLASHES / *5 FLASHES* / 6 FLASHES / 7 FLASHES Remote low battery warning *ON* / OFF Front parking sensor range NARROW / *WIDE* Rear parking sensor range NARROW / *WIDE* Mute parking sensor when stationary for more than 3 sec. YES / *NO* Lower parking sensor beep volume when stationary for more than 3 sec. *DON'T CHANGE VOLUME* / 1 / 2 / 3 Lower parking sensor beep volume when moving away from objects DON'T CHANGE VOLUME / *1* / 2 / 3 Parking sensor beep volume *1* / 2 / 3 / 4 / MAX Activate parking sensors in neutral (N) *YES* / NO Auto-turn off parking display when moving away from obstacles *YES* / NO Dash display mode ALL / *UNDISP* Lights Daytime running lights *ON* / OFF Coming-home lights duration *OFF* / 30 SECONDS / 60 SECONDS / 90 SECONDS Auto headlights activation threshold DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST Turn on marker lights when vehicle is unlocked via remote *ON* / OFF Instrument lights dimming sensitivity DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST Instrument lights restoring sensitivity DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST Dim interior lights after… 7 SECONDS / *15 SECONDS* / 30 SECONDS Turn on interior lights when you shut off engine *YES* / NO Turn on interior lights when you unlock doors *YES* / NO Turn on interior lights when smart key in range *YES* / NO Turn on exterior footlight (on side mirror) when smart key in range *YES* / NO Interior footlight (bright when doors open, dim when driving) *YES* / NO Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P) *YES* / NO Turn on exterior footlight (on side mirror) when doors unlocked via remote *YES* / NO Turn on exterior footlight (on side mirror) for… OFF / 7 SECONDS / 15 SECONDS / *30 SECONDS* Interior lights linked to footlight *YES* / NO Interior light control *ENABLED* / DISABLED Exterior light control *ENABLED* / DISABLED Heater & A/C Temperature dial calibration -2°C / -1°C / *NORMAL* / +1°C / +2°C Ambient temperature calibration -3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C A/C power *AUTOMATIC* / FULL POWER A/C ECO mode *ENABLED* / DISABLED Auto-increase blower speed when front defroster is on *YES* / NO Auto-turn on A/C when AUTO button pressed (if needed) *YES* / NO Deactivate front defroster when AUTO button pressed *YES* / NO Open vents to outside air when ignition is turned off YES / *NO* Fan speed reaches its target… SLOWLY / NORMALLY / *FAST* Other Slide driver's seat back for easy exit OFF / *SHORT* / STANDARD Obtained with Carista 3.4.3 for iOS. Download app: https://itunes.apple.com/app/id954363569 Facebook: Facebook Post |
google search it on here! lots of people talk about it.
as long as your car has that one plug under the steering wheel you should be good |
I have used in on my 2017. I played around with settings, but the one I really wanted to do, the sensitivity on the touch less
rear hatch, I could not find. |
Check again! I believe they have another update that added this issue
Originally Posted by joeRX350
(Post 9872273)
Plenty of people have used it... post in the correct thread for info.
Originally Posted by Baxter64
(Post 9872774)
Originally Posted by Exec8468
(Post 9872687)
Which adapter did you get? Good to know that at least one person has used it on an RX! Thanks!
hi their is an option for this! I just got my from Amazon today. I will send a screenshot export of all settings shortly. |
Thanks so much Satnav! This is EXACTLY what I was looking for and MORE!
Just got my Carista OBD2 adapter and it's awesome! Plug it in, turn the ignition on, and change the settings you want. I thought I would have problems connecting but nope! No set up or pairing needed!
(Post 9889102)
Originally Posted by FastFord
(Post 9889124)
And NO DEALER! yea!
does this have the ability to release the electronic e-brake when servicing the rear brakes?
Can you not just disable it from the switch in the car...ie turn it off so it doesn't come on. Or does the brake do something funny anyway so servicing the rear brakes is still difficult?
