Transmission Fluid Filter
Old 05-05-17, 05:12 PM
Cocal
Cocal's Avatar
Default Transmission Fluid Filter
Do any of you know if there is a tranny filter and if so what type in a 2017 RX 350.
Service dept says it;s a metal net type not a felt type and it never needs replacing. I'm not sure if I ought to believe them!
Thanks Guys
Old 05-06-17, 06:20 AM
Valley101
Valley101's Avatar
Read the maintenance part of your manuals. It does not list any maintenance on the transmission. Most Lexus products have been this way for a few years.
Old 05-06-17, 07:11 AM
Cocal
Cocal's Avatar
Nothing mentioned in the manual, that's why I'm asking here! I always exceed the recommended maintenance since I believe that "lifetime" means the lifetime of the warranty and I keep my cars well beyond that time period.
Old 05-06-17, 02:01 PM
kalvink
kalvink's Avatar
Toyota/Lexus has been using lifetime WS transmission fluid for a while. There is no scheduled service designed for these transmissions, but it does not mean one shouldn't service them. The transmission fluid filter is indeed a mesh screen type. The transmissions do not have a dipstick fill port, they have a bleeding straw in the drain plug. There are plenty of YouTube videos concerning the service of these transmissions.
Most people drain the fluid in the pan and refill it appropriately. Dealers do not actively try to do this service as the process can be quite labor intensive when performed per Toyota procedures.
The normally red WS fluid turns brown as it degrades from heat cycles and usage. The fluid is designed to last a "lifetime" but loses its effectiveness overtime (there is no lifetime fluid).
Old 05-06-17, 07:15 PM
mcfancy
mcfancy's Avatar
good feedback...wed be interested kn the procedures...ive scoured thru utube and nothing for 16/17 models...sale for differential and transfer case oils..nothing for this gen
Old 05-07-17, 07:00 AM
Cocal
Cocal's Avatar
Originally Posted by kalvink
Toyota/Lexus has been using lifetime WS transmission fluid for a while. There is no scheduled service designed for these transmissions, but it does not mean one shouldn't service them. The transmission fluid filter is indeed a mesh screen type. The transmissions do not have a dipstick fill port, they have a bleeding straw in the drain plug. There are plenty of YouTube videos concerning the service of these transmissions.Most people drain the fluid in the pan and refill it appropriately. Dealers do not actively try to do this service as the process can be quite labor intensive when performed per Toyota procedures.The normally red WS fluid turns brown as it degrades from heat cycles and usage. The fluid is designed to last a "lifetime" but loses its effectiveness overtime (there is no lifetime fluid).
Thanks Kelvin, just what I needed, a confirmation that what the dealer told me is true. I suppose they don't want to change the filter as it is labour intensive, my dealer has a machine that does an ATF exchange through the tranny cooler and that doesn't take too long. The service manager says the toyota's way takes way too long and the machine does a more thorough exchange, but he also told me that they never change the filter so I wanted to verify. I'm **** retentive for maintenance and don't believe in these "lifetime" fluids, in fact my oil change is every 5,000 miles and Tranny, differential & trans case every 30,000 miles. Will use Lexus fluids, but not oil filter as it looks sooo flimsy to me, for that I'll use the TRD filter, so much better in construction and filtering capability.
aachowhan
08-11-22 11:11 AM
roshedomv2
04-26-21 07:34 AM
trinhchau
09-23-16 09:52 PM
hrp
02-21-11 04:45 AM
gottahaveit2
11-23-02 06:29 PM
Quick Reply: Transmission Fluid Filter
