Lane Centering performance is bad. - ClubLexus - Lexus Forum Discussion
RX - 4th Gen (2016-present) Discussion topics related to the 2016 and up RX350 and RX450h models
Old 09-27-16, 01:26 PM
Averageann
Default Lane Centering performance is bad.
2016 RX 350
The Lane Keep Assist (LKA) works well; automatically turning the car back into the lane when starting to cross the lane lines.
However, when the Cruise Control is on and Lane Centering option is on the car does not maintain a good center. On a straight portion of a newly paved and marked interstate, with no wind, the car wavers side to side about half a lane width. Occasionally it will go as far as the lane line at which point the LKA kicks in. This is with no steering correction on my part.
If I steer to keep the car in the lane center the steering is heavy and I feel as though I am fighting what the car wants to do.
If I turn off the Lane Centering the steering is easy to keep in the center of the lane. The LKA is still on in this case.
I explained this problem to the Lexus dealer's expert and he was not aware of the Lane Centering option until I showed him the manual. He test drove it and concluded that that's the way it is until Lexus comes up with new software.
Does anybody else have this problem? The Lane Centering option is on by default only when in Cruise Control mode.
Averageann is offline
Old 09-27-16, 03:51 PM
TominBoise
TominBoise's Avatar
Mine is working the same as yours. I have found it will only try to stay centered when going straight and on a small curve. If the curve is too sharp it will go beyond the lines.
If you let go of the steering wheel you get the warning every 30 seconds to take hold of the wheel.
What happens if you do not take hold of the wheel? I have let mine go about 1 minute and it just keeps beeping.
I hope they can fix this in the software and it will be down loadable to existing cars.
TominBoise is offline
Old 09-28-16, 06:29 AM
aznkorboi
aznkorboi's Avatar
For me, it is good on a straight line. However, after a few min it will hug a lane and compensate and oversteer. But it also tells you to keep your hands on the wheels so I just use a finger and lightly nudge it back.
This isn't a mercedes or tesla. Lexus is behind on these features so don't expect anything crazy!
aznkorboi is offline
Old 09-28-16, 07:23 AM
ccb777
When I used it for a trip to Hilton Head the LCA seemed to work OK with some ping ponging. The other day I used it again and the ping ponging was severe. I did notice the road I was on had a larger than normal crown. They do need a software upgrade to make this better. Other wise you do fight the wheel some when it is on
ccb777 is offline
The Following User Says Thank You to ccb777 For This Useful Post:
DunWkg (12-31-16)
Old 09-28-16, 09:43 AM
NealKBrown
Yes, be aware of the rate of curvature of the road you're on. For me, it works great on one major highway here (loop 1) southbound, but northbound the road curves too much for it to stay in its lane. So under no circumstances can you let go of the wheel.
NealKBrown is offline
Old 12-30-16, 03:49 PM
Gatr480
Default Lane centering not functioning
2016 RX 350. Had been using cruise control with LKA and lane centering without problems, until I had the navigation system reset due to a software problem that was announced via email. I have taken two long trips to south Florida driving on major interstate highways with clearly marked lanes, and noticed the car drifting towards the right, crossing lanes with the cruise control active. My husband also noticed this as well. We were both having to actively steer the car back in between the lanes. We have tested this on many roads, and within the center lanes to be sure it was sensing the lane markers. I took the car to the dealership, and they looked at me like I was crazy. They have never heard of this problem, and neither has Lexus customer service. They thought I was trying to drive the car hands-free! (yes, I know this is not a Tesla.) Hope anyone out there has any other information on this!!
Gatr480 is offline
Old 12-31-16, 05:30 AM
toyotaman7
Lane keep assist with centering is by default turned off. I wonder if the software update turned the setting back to default value?
Check the setting in the instrument cluster settings.
toyotaman7 is offline
Old 12-31-16, 06:07 AM
ggebhardt
ggebhardt's Avatar
It does what it was designed to do and "assist" is about it.
ggebhardt is offline
Old 12-31-16, 12:06 PM
Kiboater
GM calls this Lane Keep Assist and it automatically steers the car toward the middle if you wander out of the lane. I have it on a 2016 Denali and it works about the same as Lane Centering on the Lexus. The Lane Centering term Lexus uses is misleading. My expectation was that it would be an improvement over the Denali but it is the same system with the same limitations..
Kiboater is offline
Old 01-01-17, 04:44 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
+1
The system is working as designed to be reactive in correcting the driver's input in the event the driver sways close to an adjacent lane. LKA works the same in the NX.
corradoMR2 is offline
Old 01-02-17, 04:37 PM
Gatr480
Thanks - I have gone through all of the LKA settings and made sure the lane centering is 'on', as well as adjusting the sensitivity, etc. I even tested this using cruise control on a city road, with max speed limit of 45 mph. For some reason, the car wants to drift off to the right, crossing the lane, then alert me that the car has crossed the lane, then try to overcorrect. While I'm steering, it feels like my sense of center is not the same as the car's sense of center, and I'm having to do more to keep the car within the lanes. Is there a way to reset the car software myself?
Gatr480 is offline
Old 01-02-17, 04:39 PM
Gatr480
Originally Posted by Averageann View Post
2016 RX 350
That is exactly what my RX is doing. Has any tech specialist at your dealership been able to help you with this? I put a call out to Lexus customer service, awaiting a callback.
Gatr480 is offline
Old 04-09-18, 10:26 PM
Rampy
My dealer is currently looking at changing some steering components to try and fix this problem. I had the same issue .. car pulls to a particular side quite aggressively as soon as LKA is activated. They have already tried to recalibrate the cameras and system to no effect.
Rampy is offline
Old 04-10-18, 11:23 AM
reposado2
"does not maintain a good center."
LKA isnt meant for that.
LTA(Lane tracing assist) which is coming out soon late 2018 on many toyota/lexus model should maintain a good center.
reposado2 is offline
Old 06-17-18, 06:45 AM
nyc1dxo
Default Lane Keep Assist. LKA
Iím not happy with this feature. I have a Honda with this same feature which operates efficiently. It keeps my car within the lane.
In the 2018 350L, it doesnít behave the same way. It tries to keep the car on the extreme right side on my lane and will veer off to the right triggering the alarm. I have to fight the steering wheel to move left in the lane to center it. On my Honda it will trigger an alarm but still will center the car.
Iíve check the instrument cluster and I have the system active.
For an extra $25,000 over I would think Lexus would have a more perfect system than a basis Honda.
Anyone else have similar issue?
nyc1dxo is offline
Quick Reply: Lane Centering performance is bad.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
