Winter Tires and Rims
#136
tech stream looks like toy's scanner, had to google it. more a domestic and universal guy for scan tools.
what is the trigger/scan tool, and does that work on the new rx ??
do cloned sensors work on the lexus, and wouldn't that eliminate programing ??
have to see how bad a new 450 is in the snow we get in minnesota, not looking forward to swapping snows on 2 vehicles, lol. (tire/wheel, not just tires)
#137
Tech Stream is little cumbersome to use but it does the job. Regarding trigger/scan tool, look into Autel one. trigger, scan to get the tpms ids. then connect to OBD II port, execute relearn command. That's it. Takes less than ~30 mins. at the most. Hybrid snow mode is not that good. For an example it does not have diff. lock likeregular RX. IMO, the reason is read axle has only one motor vs. Acura MDX has two motors. Also torque steer is something to note. Last week end I went out to our cabin, almost stuck in the snow. Never happened with previous cars MDX, X5, etc. NOw keep looking at GX. Cloned sensor won't do anything. You wi;; get "check tire pressure" warning, etc. I have 3 vehicles in the family. Now daughter is married away. All have two sets of rims/tires.
#138
When you want to get out of situation being stuck in deep snow diff. lock makes difference. Not talking about driving on snow.
#139
Sure thing but the RX shouldn't be in deep snow anyway. When slip is detected the hybrid engages the rear drive. It is essentially the same as a locking center diff except that it works at high speeds too, and with instant torque for that matter.
#140
X-drive... and interestingly Acura MDX hybrid has two motors for rear axle vs. one in RX.
#141
Ok got it, but in terms of hybrid vs. hybrid neither cars have 4 wheel independence. But RXs with VDIM may have the ability for brake based L-R torque distribution (which would put it in above group), but I have not tested this.
#142
looking to put snow tires on my lexus is 350. IT has sport tires and rims now.
looking to put snow tires on my lexus is 350. can you help? It is leased, and lease is up in 6 months but i plan to buy it.
#144
winter tire size with F sport 3 package
my dealer is throwing in winter tire/rim set and giving me option of 20" or 18" Blizzak DM-V2 winter tires with non-OEM alloy rims. Usually, i've gone one size smaller, but going from 20" to 18" looks like it is a lot smaller. With my 2010 RX350. my regular rims for 19" and I got 18" winters.
I think the 20" look a lot better, but from a winter driving perspective, am i better off going with 18"? Since the dealer is including either set for me, so for me cost is not a factor to consider. The dealer's normal selling price for the sets are $2900 for the 18" and $3400 for the 20".
I had read that you should go a size smaller, but I'd appreciate any feedback on what size would actually be better for winter driving, or if it even makes a difference.
#145
makes no difference, i would do 20's the width would both be comparable,
when people go smaller, its either cost, or narrower tires, smaller wheel and taller tire doesn't gain anything. still tons of tire height on the 20's
hope that makes sense.
#146
18's would provide a substantially more comfortable ride in winter when roads tend to become rougher/potholed and tire rubber doesn't flex as well. You have to substantially moderate the way you drive on winter tires anyway so you might as well be comfortable.
BTW, 17" wheels and winter tires would have worked fine on your 2010 RX and cleared the brake calipers with plenty of space and will even fit your gen 4 RX F-Sport according to Tire Rack.
I've been using Blizzaks on our vehicles since they were introduced something like 20 years ago. I always downsize the winter wheel size when possible, i.e. when smaller wheels will fit over the brake calipers, but never go with a narrower tread since doing that negatively affects braking on dry pavement.
#147
When I had RX I had winter tire on i" under size rims. It gains more traction in deep snow compared to wider tires.
#148
all things equal a 1" taller tire and smaller wheel makes zero difference. the rolling diameter is the same, and if you convery the tire size, the width is the same
.taller sidewall, sure that could be more comfortable.
#149
