Brake Hold Function
There are times when the Brake Hold interferes with normal driving. Try doing a three point turn with it on, I can see why it isn't turned on everytime you turn on the car.
I note that Lexus wrapped the Owner's Manuals in Saran Wrap this time. That way they can tell if you ever opened them when you trade in for the next one???
I figured it's because the cover of the manual is so thinly cheap that it gets dogeared just by being exposed to the air
The manual appears to be written by the legal department at Lexus. If they removed all the ridiculous warnings it would be half the size and readable.
Doesn't seem very safe. As your car is rocketing forward, take your eyes off the wheel to find a little toggle switch (that is hard to reach) as opposed to putting your hand on a big lever or using your left foot to stomp on a peddle you know is to the left.
I don’t use the Hold feature that often.
I prefer gradual acceleration and It forces you to burn more fuel in traffic since you push the gas pedal to go forward a a couple of feet instead of just letting off the brake.
i can see parking, 3 point turn things like that. i use it more and more.
Change Brake Hold Default to "On?"
Hey all,
I've read that the procedure for Brake Hold is to press the button and it activates for the duration of that drive. Is there any setting to customize this, Techstream, or otherwise, to make this default to
"on" each time the vehicle is driven? I ask because it's an amazing feature that Euro vehicles such as Mercedes, have as a standard feature, one is ALWAYS on. In fact, there is no button for this feature, you simply press the brake firmly and it holds until you accelerate again.
As this feature is IMO essential in traffic, I'd be toggling this [tiny] button every time I start the vehicle -- can anyone advise if there is any way to default the vehicle from "off," to "on?"
Thank you!!
Thank you!!
Hey all,
Thank you!!
Thank you!!
now for stop and go traffic, you could use the cruise control,
it maintains distance, holds when needed, goes when needed. hepls steer the vehicle too
only catch is it will pucker you up as you get use to the system, lol
i haven't found that pushing 1 button ruins my driving experience in the slightest bit,
thanks, however, im not really llooking to debate whether there are workarounds or whether someone feels pressing a button is less of a burden than someone else.
question is whether or not there is any way to detault the vehicle to have this on, (rather than off) at each startup. thanks
Really? Dealer was no help. Lexus corporate said cant be done. I'd love to know how your's is set and operates. So your's automatically shows "hold" every time you crank the vehicle?
