Turn on/off Air Conditioner?
Old 06-09-16, 03:17 AM
  #31
daryll40
daryll40's Avatar
Huh? What is "Carista"? And if you do this, what's involved in "going in" to turn on the AC?
Old 06-09-16, 06:28 AM
  #32
DunWkg
DunWkg's Avatar
I'm in the "I don't turn it off group". It's pretty rare I'm concerned if the compressor is running. If I want the compressor to stop running, I raise the temperature setpoint. If I don't want heat, I lower the setpoint. Leaving all the other controls in auto.
Although this is my first spring/summer in the 2016, my habits may change if they changed the climate control software/firmware.
Old 06-09-16, 07:11 AM
  #33
Vincent05
Vincent05's Avatar
Carista is a bluetooth adapter and app where you can go in and change certain settings. Search Carista and read up more on it.
Old 06-09-16, 07:49 AM
  #34
TexasRxh
TexasRxh's Avatar
I chose the OBDII WiFi mini adapter from VeePeak on Amazon ($18) cuz I have an iPhone. The app is free if you only want to look at settings. (you can change a few) But if you want to change most settings you need to pay the $19 to "upgrade" the free app to the one that actually works.
Old 07-11-16, 08:15 PM
  #35
RobertGift
RobertGift's Avatar
We want fan-assisted outside cool air. NO COMPRESSOR!
Can the fan be on without the air conditioner compressor turning on?
The vehicle's lights/siren unit has an unused switch.
Can I connect the wire to the air compressor through the switch?
Can the air compressor be turned off through the screen while the vehicle is moving?
Thank you.
Old 07-13-16, 12:13 PM
  #36
aznkorboi
aznkorboi's Avatar
Yes.
But it won't be on AUTO. But you can switch it off in the settings menu on your car.
Also, the front defogger/foot setting auto turns on the AC even though the ac button is not lit. Same goes for the full defogger. Found that out the hard way when I kept seeing dripping fluid even though I thought my AC wasn't on. Turns out they turn on the AC no matter what with the defogger settings.
Old 06-15-17, 07:38 AM
  #37
tdjacw
tdjacw's Avatar
Default Switching between AC and Vent question
I just starting using the AC and find it really strange that I cant turn the AC off and go back to vent without going
into the Climate display menu. Is there any way to switch on and off the AC without going into the menus? I dont have factory Nav display.
Old 06-15-17, 08:43 AM
  #38
Nail34
Nail34's Avatar
My wife has a '16 NX and every time I get into her car I am so envious of her A/C on/off button. I know how I do it with the Nav package, maybe someone else will let you know non-nav options.
The mpg is better with a/c off.
Old 06-15-17, 10:46 AM
  #39
tdjacw
tdjacw's Avatar
Dont know why my question got moved because there doesn't seem to be a difinitve answer to the question.
CAN YOU SHUT OFF THE AC MANUALLY AND STILL KEEP THE OUTSIDE AIR COMING THROUGH WITHOUT GOING INTO THE THE MENUS. I FIND IT REALLY ANNOYING. Every other vehicle I've owned had an on off switch for the AC.
This is one on three things I find annoying. The second is the car shuting off when getting in with the remote start. Third is no digital speedometer. Seems like that should be a no brainer for a car with all these other features.
Old 06-15-17, 11:22 AM
  #40
TeKKieNYC
TeKKieNYC's Avatar
You can keep A/C in default OFF mode.... see Climate Settings
http://www.lexus.com/pdf/service/RX_with_nav_LPS.pdf
sirtiger (06-23-17)
Old 06-15-17, 11:50 AM
  #41
aznkorboi
aznkorboi's Avatar
Here is what I learned that works really well for me.
I have the 12.3 inch display.
On the left side, I have my audio that shows me what I'm playing. I don't use the maps at all.
On the smaller right side, I have the temperature calibrations.
I don't like the compressor being on all the time for "Auto." So this is what I do.
I keep it on Auto, but I turn off the A/C by using the mouse and pressing A/C. This allows me to have the computer adjust the speed of the fan based on the temperature I want. I also have the air on outside air most of the time. If you want to put inside air, press the button. Pressing it again turns the inside/outside air to AUTO, which turns ON the AC. Pressing a third time, leaves the air on outside air.
When it gets super hot, I simply press the "AUTO" button again, this turns ON the A/C, and I lower the temp to 61, or Lo, etc. This also automatically turns the air to inside air.
When it gets nice and cool, I'll either raise the temp to about 70 or, I'll move my mouse cursor and turn off the A/C button. When I turn OFF the A/C, this automatically turns my inside air to fresh outside air.
Also, the vents automatically go to outside air when I turn off my engine no matter if I have it on inside or outside. This is most likely to prevent that smelly mold smell that many cars have when leaving the A/C on and not allowing the condensation to dry with outside air.
FastFord (06-15-17)
Old 06-15-17, 11:55 AM
  #42
FastFord
FastFord's Avatar
No you can not just shut the air off...No button and I agree it should have one. The 3RX didn't have one either. As stated above the dealer can change the default to off.
We must have different models cause all I have is a digital speedo.
Someone else will have to answer the remote turning the car off when you get in. That doesn't make sense.
Old 06-15-17, 12:02 PM
  #43
FastFord
FastFord's Avatar
Aznkorboi....that's pretty cool use of your controls...I never even thought to turn off the map....I don't use it anyway..well at least 95% of the time.
Old 06-15-17, 12:05 PM
  #44
aznkorboi
aznkorboi's Avatar
haha yeah. and if you do need the maps, it's one quick map button press next to the mouse joystick
Old 06-15-17, 12:07 PM
  #45
aznkorboi
aznkorboi's Avatar
everyone hates the engine turning off feature. It's a whole separate thread. If that angers you, you're gonna be even more angry once your enform subscription ends and you can't auto start the engine with your remote anymore!
Quick Reply: Turn on/off Air Conditioner?
