How do you mount front license plate?
#46
there are two indents where you drill. 1/4" bit i think.
#47
#50
How to install front plate on a 2017 Lexus RX 350
The front plate holder is found under the mat at the rear where the spare is kept. Save the 2 screws packed with it.
Install the plate holder on the front between the 3rd and 4th “slat” below the Lexus emblem and be it is centered below the emblem. You will see two indented places with holes for screws. Take the 2 sheet metal screws supplied with the plate holder and, with a power drill screw them in. Alternatively you can drill 2 holes and then use a screwdriver to fasten them.
You should mount the the license plate using the holes on the top of the plate.
You are done.
If if this sounds like too much work your Lexus dealer will do it for you.
JH
You are done.
JH
ravenuer (12-07-17)
#51
2017 rx 350 f sport
I just purchased a 2017 rx 350 f sport it came with a front license plate frame but it is not attached,how does it attach .
Is the regular rx 350 frame different? The grills are different.
#52
Hi, and welcome to the site. Lot's of great information here. You would be better served if you posted to the correct forum:
https://www.clublexus.com/forums/rx-...6-present-273/
Again WELCOME!!!!
Lou
Again WELCOME!!!!
Lou
finny76 (12-26-17)
#53
License plate frame
I just purchased a new 2017 rx 350 f sport, i found the front license plate frame in the trunk b y the spare tire. How does this attach & the grill and the f-sport front grill is different from the rx-350. Are the license plate frames the same. I cant find any hardware.
#54
Tech Info Resource
Thread moved to correct forum.
#55
Should be two screw bolts in the bag with the holder. There are two indents on the Fsport grille that show you where to drill. I think I used a 1/4 bit when drilling mine. Super easy.
#57
#58
How about using the RX's Towing Eyelet?
I've been driving my RX around without a front license plate...crossing my fingers that I don't get pulled over forced to install it.
If I do have to install the front license plate I think that I'll use one of the "Front Bumper Tow Hook License Plate Mounting Brackets" that you see on Ebay, screwed into one of the front towing eyelets (refer to the picture from the RX Manual below) on the RX. It looks like the towing eyelet cover has a tether, I haven't looked into the details yet.
#59
so for the rx350 f sport, the plate holder is attached to the f sport grille via 2 self tapping screws.
but, I'm missing two screws to attach the license plate to the "plastic plate holder"
what size screws are they?
#60
