Customizing the panoramic view monitor
I was told by my salesman that it's possible to change the color of the car on the monitor.
He has challenged me to try and figure this out on my own.
Seems as though I read something about it here but I can't find it again.
Anyone have any info on this?
Anyone with the carista app confirm if this is fixable since that would be a god send to some. Dont know why certain features like this are not already customizable from remote touch
Here you go:
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / *5* / 6 / MAX
Beep when opening/closing windows with remote
*YES* / NO
Warn when door can't be locked with remote because it's open
*YES* / NO
Warn when a window is still open when locking doors
*YES* / NO
Warn when sunroof is still open when locking doors
*YES* / NO
Panic function on remote
*ENABLED* / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Unlock doors via physical key
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Auto-lock all doors
DISABLED / WHEN SHIFTING INTO GEAR / *WHEN VEHICLE STARTS MOVING*
Auto-unlock all doors
DISABLED / WHEN SHIFTING INTO PARK (P) / *WHEN DRIVER'S DOOR IS OPENED*
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Open trunk via smart access button
DISABLED / DOUBLE CLICK / *LONG PRESS*
Open windows and sunroof by holding key in door lock
ON / *OFF*
Close windows and sunroof by holding key in door lock
ON / *OFF*
Open windows and sunroof via long-press on remote
ON / *OFF*
Auto fold side-view mirrors (req. power folding mirrors)
WITH IGNITION / *WITH DOOR LOCKS* / DISABLED
Lower passenger-side mirror when in reverse gear (req. memory seats)
DEFAULT / *USER-SPECIFIED*
Instruments / Display / Dings
Engine start indicator
*ON* / OFF
Display odometer after ignition is turned off for…
*30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Ding when headlights are left on
*YES* / NO
Seat belt warning ding (driver)
Seat belt warning ding (front passenger)
Turn signal click volume
LOW / *MEDIUM* / HIGH
Lane-change turn signal auto-flasher count
OFF / *3 FLASHES* / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
Remote low battery warning
*ON* / OFF
Front parking sensor range
NARROW / *WIDE*
Rear parking sensor range
NARROW / *WIDE*
Mute parking sensor when stationary for more than 3 sec.
YES / *NO*
Lower parking sensor beep volume when stationary for more than 3 sec.
*DON'T CHANGE VOLUME* / 1 / 2 / 3
Lower parking sensor beep volume when moving away from objects
DON'T CHANGE VOLUME / *1* / 2 / 3
Parking sensor beep volume
1 / 2 / *3* / 4 / MAX
Activate parking sensors in neutral (N)
*YES* / NO
Auto-turn off parking display when moving away from obstacles
*YES* / NO
Dash display mode
*ALL* / UNDISP
Lights
Daytime running lights
*ON* / OFF
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
*ON* / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Interior footlight (bright when doors open, dim when driving)
*YES* / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
*YES* / NO
Turn on exterior footlight (on side mirror) when smart key in range
*YES* / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
*YES* / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / *15 SECONDS* / 30 SECONDS
Interior lights linked to footlight
*YES* / NO
Interior light control
Exterior light control
Heater & A/C
Temperature dial calibration
-2°C / -1°C / *NORMAL* / +1°C / +2°C
Ambient temperature calibration
-3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
A/C ECO mode
Auto-increase blower speed when front defroster is on
*YES* / NO
Auto-turn on A/C when AUTO button pressed (if needed)
*YES* / NO
Deactivate front defroster when AUTO button pressed
*YES* / NO
Fan speed reaches its target…
SLOWLY / *NORMALLY* / FAST
Other
Slide driver's seat back for easy exit
OFF / *SHORT* / STANDARD
Obtained with Carista 2.6 for iOS.
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Auto-lock all doors
ON / *OFF*
ON / *OFF*
ON / *OFF*
*ON* / OFF
*YES* / NO
*ON* / OFF
NARROW / *WIDE*
NARROW / *WIDE*
YES / *NO*
*YES* / NO
*YES* / NO
Dash display mode
*ALL* / UNDISP
Lights
*ON* / OFF
*ON* / OFF
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Heater & A/C
A/C ECO mode
*YES* / NO
*YES* / NO
*YES* / NO
Other
heres what he typed but from Lexus in PDF form
http://www.lexus.com/pdf/service/MY1...on-Display.pdf
coolsaber was asking specifically what the carista app was able to change, not for LPS
Please do. I'm at almost 3000 miles. I'm curious what the image will look like when changed to a darker color.
just came back from dealer the other day and the service advisor had no clue on how to change the color of the vehicle in panoramic view. He looked into it supposedly and couldn't find any answers on it either so i'm still stuck with the white color. I will try another dealer on my 10k visit with another dealer.
My information came from my salesman, who is very tec savvy. He said he double checked with service technician and it was possible.
Next time I'm down there I'll ask again.
