Reverse lights LED upgrade
Old 12-17-15, 07:43 PM
PatrickXu
PatrickXu's Avatar
the LED spec is T10 or T15 or others?
Old 12-20-15, 05:13 PM
noeldavid
noeldavid's Avatar
Did the Rogue reverse LED's from Amazon JDM ASTAR 800 lumens. Very bright.
Endopax (11-09-19)
Old 12-20-15, 05:16 PM
noeldavid
noeldavid's Avatar
Took about 2 minutes and $22. Big difference when looking back while in reverse
Endopax (11-09-19)
Old 12-20-15, 08:00 PM
VinceCL
VinceCL's Avatar
^ Holy cow, does the touch free power tailgate work from that far away?? Har, har, har!
The following 2 users liked this post by VinceCL:
bibika027 (07-01-19), DFWTrooper (01-30-23)
Old 12-25-15, 09:44 PM
Lubber
Lubber's Avatar
Thanks to the info in this thread I updated my backups and the interior cargo lighting to the LEDs off Amazon. Both were extremely easy to do and had no issues. The biggest difference I notice is with the cargo lighting upgrade. Huge difference in lighting, and I say this is a must do upgrade. The cost is minimal but the results are nice. As far as the backups, I only see a small amount of increase in brightness, although going to LEDs has a nice look effect. Maybe I should have went with brighter LEDs.
Old 01-15-16, 05:27 AM
macdee
macdee's Avatar
Default Parking lights LED upgrade
Was surprised to find out that even though most of external lights are LEDs, parking lights on 4RX were still standard bulbs! I mean… really?…
So I've upgraded them today with T16, 6500K, 900 lumen LEDs. A 3 minute work, and a huge difference!
The job is REALLY easy
- use a plastic card to remove two credit card-sized covers on the inner side of the back door
- turn the outer/upper light holders counter-clockwise to remove them
- replace bulbs
- re-insert and place covers back
Before:
Another before shot:
What the hell?… a 1 cent parking bulb in an all LED 4RX??:
After short:
Another after short:
That's what I used… Japan here, so availability in other countries might vary.:
Side-by-side:
Old 01-26-16, 05:18 PM
ursa99
ursa99's Avatar
Default Link to order bulbs please...
Thanks for doing the spadework on this. Would you provide a link to order the bulbs please?
Ursa
- replace bulbs
Before:
After short:
Side-by-side:
Old 01-26-16, 05:28 PM
aznkorboi
aznkorboi's Avatar
are you serious?!
I have to change like every bulb in my rx when I get it....
Old 01-26-16, 05:48 PM
aznkorboi
aznkorboi's Avatar
Amazon.com: Philips 921 T16 retrofit X-tremeVision LED Exterior light (Pack of 1): Automotive Amazon.com: Philips 921 T16 retrofit X-tremeVision LED Exterior light (Pack of 1): Automotive
maybe these will fit?
Old 01-26-16, 08:34 PM
450h4bvrs
450h4bvrs's Avatar
Sorry for the dumb questions but are these just the reverse lights?
I replaced the reverse lights with the Phillips Amazon linked bulbs below and absolute difference, worth the $50
Old 01-27-16, 05:21 AM
SoKali-RX
SoKali-RX's Avatar
Will not fit, housing on bulb is way too big, I tried already lol
Old 01-27-16, 05:37 AM
RXOwner
RXOwner's Avatar
I am quite happy with my light s now. Them not being LED does not disturb me in the least.
Old 01-27-16, 05:44 AM
aznkorboi
aznkorboi's Avatar
haha ok thanks!
Old 01-27-16, 06:39 AM
450h4bvrs
450h4bvrs's Avatar
The phillips leds did fit, after installing new bulb the twist lock would only go in one way. It would not go in if the gray twist piece was out of alignment, it was not just a plug-n-play it took a little wiggling no force though. For me it doesnt really matter if they are incandescent or LED it was that the LED's are a bright white and brighter in general, (nice benefit that these will probably never burn out, not a big deal though) the wife liked them and she is the primary driver.
Old 01-27-16, 07:15 AM
SoKali-RX
SoKali-RX's Avatar
That's weird because the housing was clearly bigger than the socket when I tried installing it. No amount of wiggling would've made that bulb fit...
Quick Reply: Reverse lights LED upgrade
