4RX Interesting Discoveries Thread (Good or Bad)
#151
Unfortunately, found no exact model on the US Amazon store, but you could probably import from Japan if you'd like…*or maybe it goes under a different model name in the US.
I also searched high and low, and even bought one… ( http://goo.gl/6o2oOt ) This one is pretty good tech-wise, but I never installed it after trying it out. Just WAY too huge, especially annoying for the front passenger.
The DREC 4000 is not very good sensor-wise. Only 720p (1Mpix resolution)…*but because it's a separate type, it is really small. Just the camera, with built-in GPS module goes on the front glass, the small microphone thingy goes on dashboard, and the recorded itself goes inside the glove box.
The recorder supports HDR recording, and records in MP4 format, which is directly readable by Lexus navigation (just put recorder's SD inside micro-SD slot of the navi). Image quality is not extremely good, but not too bad either. You can try to search vids on youtube, just enter the model number.
So well… I can't tell I'm extremely satisfied, but that's the best I found that fits my needs to a decent degree. Hope there's an upgraded model coming out soon…
Here's the link on Amazon JP:
http://goo.gl/8Svxjx
#152
Tire pressure is now by individual tire location. My left rear tire was 2 psi to high (cold tire pressure) so was easy to locate and correct. Also nice to know our 2016's still come with nitrogen air, at least according to the green cap N2 nitrogen valve covers on the tires. My door says psi supposed to be 33 psi cold tire pressure, but seems like dealers usually do 36 psi whether new car delivery, or during service.
Attachment 379128
Attachment 379128
Enjoy!
#153
Did you guys know there is a mini storage compartment on the left hand side of steering wheel under the buttons? Just press the button and it pops open. Maybe other lexus models have this but I havent driven a lexus in a while!
Just saw that today...I feel so stoked
#154
There's also a little side bin thing on the left of the passenger seat, both door side pockets expand, with a cupholder of sorts in each.
#155
Comes in very handy.
#156
This might go without saying...
In the f-sport, the odometer reading was turned off when I picked up the car. Took me a while to figure out that pressing the "ODO/Trip" button will display the odometer and trip meters on the center tachometer. Looks better with it switched off, giving it a much cleaner look
#157
When you activate your turn signal, the front swoosh light no longer turns off on the blinking side. This always bugged me so I am glad it is no longer necessary.
I want to get that cool sequential turn signal light that is standard in Japan. Do you need an entire new tail light assembly or is it just software? It looks sick.
Lexus New RX200t/RX450h ??? Turn signal flowing (æµã‚Œã‚‹ã‚¦ã‚¤ãƒ³ã‚«ãƒ¼ 発売å‰) - YouTube
#158
#159
This is probably because Lexus hasn't figured out 8-speed engines yet. A real bummer. When the RC came out, this was a major complaint and the main reason I don't own one. Lexus tends to care about certain driving conditions and not daily drivers. I've been long Lexus, but they need to get this figured out and reprogrammed. Personally, I don't care for the 8-speeds in any car. They either change to quick or can't find the right gear
#160
Yes, I agree. I have a 2012 ISF with the 8 speed transmission and its quite amazing. I am still amazed how well the transmission performs. I also had the 2013 f-sport RX350 with the first time 8 speed transmission, and it drove much smoother than the 6 speed equivalent.
#161
I have no complaints about the 8 speed tranny but do not like how it is programmed to stay at such low RPM when driving conservatively. Need a setting somewhere between normal and sport.
#162
Yes!!
We've been driving around the new RX over the weekend since purchasing last Wesnesday and we noticed a fizzing/hissing sound coming from the engine bay while the climate control is on. Particularly when it is set to auto whether AC is on or not. I thought it was the AC compressor but I'm not sure if it is because it is constant and quite noticeable while idling at a traffic light and it also elicited a comment from my wife. If I turn off the climate control/fan off entirely the sound goes away shortly after. Does anyone else experience this? I have an FSport 350 and was wondering if this was by design or if it's an issue. Any feedback would be appreciated.
My AC makes a "water" sound, but only when the AC is on.....I am currently fighting with the dealer who wants to say it's "normal". It's driving me nuts!!
#163
I'm so glad to know I'm not crazy. I've been fight with my dealer about this "gurgling" noise for over a month now. Matter of fact I have a meeting with the GM and the regional FTS from Chicago today. Has anyone else actually complained, and what resolution did you get?
#164
#165
I had the service supervisor "hear" it. Then they put me off until the regional FTS could come to town and "hear" it. At which time he stated it was "normal" and nothing would be done. I then called Lexus NA and the General Manager of the dealership. They are bringing the FTS back today to ride with me and the GM. I don't expect they will give me any answer other than it's "normal". I tried explaining that if it were normal then every other car I've ever driven and they sell would make the same noise. Sadly, I believe this will be a no win situation for me. Only hoping as more of these roll out and the need for AC becomes necessary with summer that more complaints will arise as people from the cold weather states begin hearing it.
