Side view mirror unable to adjust in Reverse
it has been snowy weather for last couple of days. Noticed yesterday during Reverse, righy side view mirror keeps trying to adjust the mirror but something is not working right.
Has anyone faced similar issue? Still under warranty, thinking of taking it to dealer , would he charge for diagnosis ?
https://imgur.com/a/npXsxJZ
You should adjust the mirror angles to use when driving forward while in Drive or Park.
You should adjust the mirror angles to use when reversing while in Reverse.
The video seems to show that it is trying to move beyond its range. Try readjusting the
mirror position while in reverse to a more centered angle.
The 1/2/3 Memory system will memorize the forward driving position(s) but does not link
the reversing position, all drivers of the car will get the setting. Note: if you "center" the
mirror position rocker (some models) or turn off both the left and right buttons (other models)
you will defeat the dip down feature for all drivers.
When I have the same problem with my mirrors, I spray the inside of the side mirror housing with 90% rubbing alcohol.
This will work as a de-icer and 10 mins later usually mirror can fold/unfold and adjust in reverse.
b2884987
RX - 3rd Gen (2010-2015)
20
Nov 28, 2025 07:55 PM
xristos86
NX - 1st Gen (2015-2021)
Feb 14, 2025 12:58 PM
