Seat Heater auto mode
I'm confused. The seat heaters on "Auto" are set at the individual switches located forward of the "gear shift lever". Once set on automatic they do their thing. I have never (on my 2018 Rx) seen any read out for temp or setting. The "Cabin Heater" setting (Auto or Manual) has no effect on the temperature numbers appearing on the console for cabin heater desired temp. Don't think "Dual" has anything to do with the seat heaters.
makes sense, just hard to imagine what the sears would sense that would lead to different temp settings on startup.
By temp, I meant intensity, ie 3 dots, 2 dots or 1 dot
I believe the seat heat intensity (number of lights) is linked to the cabin temperature setting, and the deference between that setting and the outside temperature. If you raise the cabin temperature you will see the number of lights increase. If the outside temperature is very cold, and the cabin temperature is at 70 or so, more lights will come on at startup. Can’t confirm this with fact - just an observation.
I found that the first time you hit the heated seat button you will see the 3 amber lights for heat come on, as well as the little green light by the AUTO sticker. And from that point any time I used remote car starter, or got in and started the RX350 then the heated seats automatically came on.
When I hit the car heater seat button a second time you will notice all 3 little amber temperature lights will stay on but the little green light next to the auto will shut off. And then it operates like normal heated seats.
So if you're looking for them to come on every time you get in, or start that is how mine works. My problem was the heated seats were always coming on, and I HATE heated seats with a passion. So I had to figure how to make sure they stayed off.
Also I was told that when the heated seats are set to auto they will match the temperature you set on the thermostat, so if you're looking for them to get hotter or cooler you need to take them off auto to play with all that.
I’ll check the custom settings. Haven’t found them yet.
